I setup an association between an lzw31-sn and 2x lzw42s. The association was very slow with groups 2 and 4 setup. Once i added group 3 it was much better. The switch and bulbs are all with 5 feet of each other. Is this the expected behaviour?
Second question. Is it possible to sync the led bar with dimming? Currently it stays at 100% regardless of dimming.
Parameters are below:
| Name | Type | Value |
| paragraph | ||
| paragraph | ||
| debugEnable | boolean | |
| disableLocal | enum | 1 |
| disableRemote | enum | 1 |
| enableDefaultLocalChild | boolean | |
| enableDefaultZWaveChild | boolean | |
| enableDisableLocalChild | boolean | |
| enableDisableRemoteChild | boolean | |
| infoEnable | boolean | |
| parameter1 | number | 2 |
| parameter10 | number | |
| parameter11 | number | |
| parameter12 | number | |
| parameter13 | enum | |
| parameter13custom | number | |
| parameter14 | enum | |
| parameter15 | enum | |
| parameter16-1a | enum | |
| parameter16-1b | enum | |
| parameter16-1c | enum | |
| parameter16-1d | enum | |
| parameter16-2a | enum | |
| parameter16-2b | enum | |
| parameter16-2c | enum | |
| parameter16-2d | enum | |
| parameter16-3a | enum | |
| parameter16-3b | enum | |
| parameter16-3c | enum | |
| parameter16-3d | enum | |
| parameter16-4a | enum | |
| parameter16-4b | enum | |
| parameter16-4c | enum | |
| parameter16-4d | enum | |
| parameter16-5a | enum | |
| parameter16-5b | enum | |
| parameter16-5c | enum | |
| parameter16-5d | enum | |
| parameter17 | enum | |
| parameter18 | number | |
| parameter19 | number | |
| parameter2 | number | 2 |
| parameter20 | number | |
| parameter21 | enum | 1 |
| parameter22 | enum | 0 |
| parameter3 | number | |
| parameter4 | number | |
| parameter5 | number | |
| parameter51 | enum | 0 |
| parameter52 | enum | 1 |
| parameter6 | number | |
| parameter7 | enum | |
| parameter8 | number | |
| parameter9 | number |
@EricM_Inovelli I see you just pushed out new DH for child led. Will this fix my issue? I can test in a few hours.
