LZW31-SN Dimmer acting like On/Off after firmware update
One of my LZW31-SN (Red Dimmers) was on rare occasions seemingly acting up where the power to the lights would dim for a second and come back up, while the other switches on the same line were fine. While it seemed both more likely to be a power issue (although house is relatively newer build), I figured I hadn’t looked for firmware updates in a while, so I’d update that and the other dimmer switch in the same room before swapping out devices.
Oddly, both now function like on/off - if on, it’s at full brightness, regardless of what the dimmer bar level shows or the switch reports back to the hub. I tried telling it to dim down all the way over 10s, and the bar shows it going down, but everything is full brightness still
  1. Starting firmware: 1.52
  2. Updater: Hubitat C7 Device Firmware Updater app
  3. I updated to the latest beta that was out: LZW31-SN_1.61, confirmed successful
  4. Air gap reset after it was acting weird
  5. Re-saved preferences
  6. Air gap reset again
  7. Downgraded firmware to 1.57
  8. Air gap reset - still same issue
  9. Downgraded back to the original 1.52
  10. Air gap reset, still same issue
Any ideas/suggestions? Or any other info I could provide to help troubleshoot? Thanks!
Check to see if smart bulb mode is enabled? That seems like what it would do in that mode.
Agreed toggle SBM on and off
Thanks! It was set to disabled already, but toggling it to Smart Bulb mode, saving, and then back to disabled fixed it! I appreciate both of your responses :slight_smile:
I’ve got a similar issue. The Dimmer lost its identity on my Indigo controller (generic switch) and kept activating local switch scenes when pressed (setting a default dimming level not initiated by the hub), but was still a dimmer. I excluded it and included it, now it thinks it’s an SBM switch. I’ve tried toggling the SBM parameter, and a factory reset, but still the same behavior. Any advice?
Resolved: Somehow parameter 158 got set to a switch. It had been working fine as a dimmer…Purchased a new one thinking it was faulty, but the new one was the same…Oops. All working fine now. The old unit was very unresponsive, so I may have had two issues…
