Hello,
Just updated one of my Red Dimmers to Firmware 1.61, and the device is now unknown. I think this could be a issue with ZWaveJS but not sure yet. Just putting this up as warning for people. Because right now i cannot do a ota to 1.57 because ZWAVE JS thinks the device does not support it.
edit:
I am using S2, not sure if that makes a differents
Thanks,
Jeremy
stu1811
October 25, 2021, 6:55pm
#2
Weird. I updated all of my dimmers to 1.61 and they were fine
PJF
October 25, 2021, 6:59pm
#3
Try re-interviewing it. The zwaveJS database limitations are only within a firmware range or >= the firmware so it should use the data and parameters the same as 1.57 without any issue.
this all i get
2021-10-25 12:23:17.002 INFO APP: GET /api/settings 304 74.226 ms - -
2021-10-25 12:23:17.070 INFO APP: GET /api/auth-enabled 304 6.976 ms - -
2021-10-25 12:23:24.626 INFO ZWAVE: Calling api refreshInfo with args: [ 63, [length]: 1 ]
2021-10-25 12:23:24.652 INFO ZWAVE: Node 63: interview started
2021-10-25 12:23:24.666 INFO ZWAVE: Success zwave api call refreshInfo undefined
2021-10-25 12:23:24.684 INFO ZWAVE: Node 63: interview stage PROTOCOLINFO completed
2021-10-25 12:23:24.841 INFO ZWAVE: Node 63: interview stage NODEINFO completed
2021-10-25 12:23:25.078 INFO ZWAVE: Node 63: metadata updated: 38-0-Up
2021-10-25 12:23:25.080 INFO ZWAVE: Node 63: metadata updated: 38-0-Down
2021-10-25 12:23:35.206 INFO ZWAVE: Node 63: interview stage COMMANDCLASSES completed
2021-10-25 12:23:35.210 INFO ZWAVE: Node 63: interview stage OVERWRITECONFIG completed
2021-10-25 12:23:35.212 INFO ZWAVE: Node 63: interview stage COMPLETE completed
2021-10-25 12:23:35.217 INFO ZWAVE: Node 63: value added 63-38-0-targetValue => undefined
2021-10-25 12:23:35.217 INFO ZWAVE: Node 63: value added 63-38-0-duration => NaNs
2021-10-25 12:23:35.220 INFO ZWAVE: Node 63: value added 63-38-0-currentValue => undefined
2021-10-25 12:23:35.220 INFO ZWAVE: Node 63: value added 63-38-0-Up => undefined
2021-10-25 12:23:35.221 INFO ZWAVE: Node 63: value added 63-38-0-Down => undefined
2021-10-25 12:23:35.223 INFO ZWAVE: Node 63 ready: Unknown manufacturer 0xXXXX - Unknown product 0xXXXX (0xXXXX)
2021-10-25 12:23:35.229 INFO ZWAVE: Node 63: interview COMPLETED, all values are updated
2021-10-25 12:23:46.538 INFO APP: GET /health/zwave 200 1.572 ms - 1873
stu1811
October 25, 2021, 7:28pm
#6
HA Supervised add on zwavejs2mqtt 0.27.0
ZwaveJS2Mqtt v5.8.0
Edit: I see you’re using S2. All of my have security=none.
yes, i just re added the upgraded node with no security and it working right
now, i am confused…after adding back with s2 it works like it should…
stu1811
October 25, 2021, 8:00pm
#9
is it only one device or multiple? glad to hear you got it working.
so far, just one device! but that was fixed after adding back to the network
The only thing different this time around I updated my Aeotec 7 stick per this link.
