I’m trying to setup the LZW42 RGBW bulb to be controlled by the red series dimmer. Want to confirm a few settings in the dimmer.
Hub: SmartThings
Wiring Setup: neutral, single pole
Using the Zwave Association Tool, I setup Groups 2 and 4 with the dimmer as the source, bulb as the destination.
Disable Local Control - that should be Yes to keep the power to the bulb, correct?
At the bottom of the dimmer settings page, it has a Child Devices section with 4 on/off toggle options:
Disable Remote Control
Default Level (Local)
Default Level (Z-wave)
I can’t seem to find more details on what these Child Device settings are really for. Right now, I have them all off (the default). What do these do, and should any be enabled when using the zwave association for the Ilumin bulb?
