- Load: 9.8w x 6 = 58.8W
- The LED bar is NOT lit up when switch turns itself off. Cycle is: OFF (bar is dimly lit) -> push ON (briefly lower quarter of bar lights up, then full bar lights up) -> turns OFF (bar is dimly lit)
I’m having the damnedest time getting HA to show the config options, so I can’t get into the 80% game right now.
Logs are below:
- Turn off via dumb paddle
- Turn on via switch, watch it turn itself off
- Turn on via dumb paddle, watch circuit remain on.
# Switch Debugging:
== Turned circuit off via dumb paddle switch (switch in down position):
2020-09-30 08:49:08.446 Detail, Node012, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x26, 0x03, 0x00, 0xb5, 0x00, 0x6f
2020-09-30 08:49:08.447 Detail,
2020-09-30 08:49:08.451 Info, Node012, Received SwitchMultiLevel report: level=0
2020-09-30 08:49:08.451 Detail, Node012, Refreshed Value: old value=99, new value=0, type=byte
2020-09-30 08:49:08.451 Detail, Node012, Changes to this value are not verified
2020-09-30 08:49:08.451 Detail, Node012, Notification: ValueChanged
2020-09-30 08:49:26.079 Detail, Node012, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x26, 0x03, 0x00, 0xae, 0x00, 0x74
2020-09-30 08:49:26.079 Info, Node012, Received SwitchMultiLevel report: level=0
2020-09-30 08:49:26.079 Detail, Node012, Refreshed Value: old value=0, new value=0, type=byte
2020-09-30 08:49:26.080 Detail, Node012, Changes to this value are not verified
2020-09-30 08:49:26.080 Detail, Node012, Notification: ValueChanged
== Turned circuit ON via LZW31 switch
2020-09-30 08:49:27.122 Detail, Node012, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x26, 0x03, 0x63, 0xb1, 0x00, 0x08
2020-09-30 08:49:27.122 Info, Node012, Received SwitchMultiLevel report: level=99
2020-09-30 08:49:27.122 Detail, Node012, Refreshed Value: old value=0, new value=99, type=byte
2020-09-30 08:49:27.122 Detail, Node012, Changes to this value are not verified
2020-09-30 08:49:27.122 Detail, Node012, Notification: ValueChanged
== Switch turned OFF by itself
2020-09-30 08:49:27.958 Detail, Node012, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x26, 0x03, 0x00, 0xb1, 0x00, 0x6b
2020-09-30 08:49:27.959 Detail,
2020-09-30 08:49:27.959 Info, Node012, Received SwitchMultiLevel report: level=0
2020-09-30 08:49:27.959 Detail, Node012, Refreshed Value: old value=99, new value=0, type=byte
2020-09-30 08:49:27.959 Detail, Node012, Changes to this value are not verified
2020-09-30 08:49:27.959 Detail, Node012, Notification: ValueChanged
2020-09-30 08:49:39.752 Detail, Node012, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x26, 0x03, 0x00, 0xb0, 0x00, 0x6a
2020-09-30 08:49:39.752 Info, Node012, Received SwitchMultiLevel report: level=0
2020-09-30 08:49:39.752 Detail, Node012, Refreshed Value: old value=0, new value=0, type=byte
2020-09-30 08:49:39.752 Detail, Node012, Changes to this value are not verified
2020-09-30 08:49:39.752 Detail, Node012, Notification: ValueChanged
2020-09-30 08:49:41.421 Detail, Node012, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x26, 0x03, 0x63, 0xae, 0x00, 0x17
2020-09-30 08:49:41.421 Info, Node012, Received SwitchMultiLevel report: level=99
2020-09-30 08:49:41.421 Detail, Node012, Refreshed Value: old value=0, new value=99, type=byte
2020-09-30 08:49:41.421 Detail, Node012, Changes to this value are not verified
2020-09-30 08:49:41.421 Detail, Node012, Notification: ValueChanged
2020-09-30 08:49:43.479 Detail, Node012, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x26, 0x03, 0x00, 0xb3, 0x00, 0x69
2020-09-30 08:49:43.479 Info, Node012, Received SwitchMultiLevel report: level=0
2020-09-30 08:49:43.480 Detail, Node012, Refreshed Value: old value=99, new value=0, type=byte
2020-09-30 08:49:43.480 Detail, Node012, Changes to this value are not verified
2020-09-30 08:49:43.480 Detail, Node012, Notification: ValueChanged
== Turned circuit ON via dumb paddle (stays on)
2020-09-30 08:49:50.398 Detail, Node012, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x03, 0x26, 0x03, 0x63, 0xb5, 0x00, 0x0c
2020-09-30 08:49:50.398 Info, Node012, Received SwitchMultiLevel report: level=99
2020-09-30 08:49:50.398 Detail, Node012, Refreshed Value: old value=0, new value=99, type=byte
2020-09-30 08:49:50.398 Detail, Node012, Changes to this value are not verified
2020-09-30 08:49:50.398 Detail, Node012, Notification: ValueChanged
