LZW36 - Fan with no light attached + Hue lights in a floor lamp
Hello!
So before I buy the Fan + Light Switch I wanted to check and see if it would work for my scenario.
I’m planning on buying the Minka Aire Roto Ceiling Fan for my bedroom. It does not have any attached lights. Ideally, I would like to use the Fan part of the switch to control the fan speed and the Light part of the switch to kick off a scene to turn on some Hue lights around the bedroom. Would that be possible?
Thanks in advance!
It appears to have an AC motor so you should be good from that perspective.
I would check to make sure the Inovelli canopy module will fit. I didn’t see any canopy cover specs on Minka’s site.
