LZW36 Issues - Local Control stops working after adding switch
@NicksGarage FYI there is an update to the driver that changes the fan component to “Hampton Bay Fan Component” adds easier to access speeds and breeze mode.
Update in the last few hours?
Please see this post:
This is just for the child devices?
Just for the fan child device in Hubitat on mine. The light child uses a “Generic Component Dimmer” driver…
I am having the same problem @Sky320 is having. I have to airgap the switch to get it up and running again. I do have the latest driver up and running and I’ll keep my eye out for updates. I did just change the Local Protection Settings to “None” as @EricM_Inovelli mentions above. I’ll report back to see if that helps solve it.
I have two of the fan/light controllers and seem to be having very similar problems to the rest of the people in this thread.
Everything is fine with the wall switches until I send any changes from hubitat. Once I do anything from hubitat its a crap shoot what will happen next. Sometimes my physical switches don’t work or the light will work and not the fan, or really any combination you can think of. Once they get goofy I have to get them to an off state and air gap the switch to bring it back to operational.
I tried setting the protection option to fan and then back to none but that didn’t change anything
I attempted to update the firmware on them using the Hubitat Z-Wave firmware update tool to:
http://files.inovelli.com/firmware/LZW36/Beta/LZW36_1.34.gbl
But it gets to a Padding message and never continues (was afraid to keep messing with it after the 3rd try)
I am using the driver dated 2020-06-02 and the child fan device is the Hampton Bay.
Any suggestions?
I to am having some what of a similar issue. I can control the fan just fine with the physical switch as well from the Hubitat dashboard. The lights I can control just fine from the physical switch but when I try to control from the dashboard it just hangs with the hour glass icon and never does anything.
I have verified that I have the latest driver code dated 07/12/2020. I have the Hampton Bay Light and Fan components correctly selected in each of the child devices.I have used the air gap switch to reset and reboot the hub with no change. Also I just updated the Hubitat hub t the latest firmware 2.2.2.123 with no change either.
@EricM_Inovelli – can you check out this thread when you get a chance?
Also, @Ma2J – I know you’re a Hubitat user and have the fan/light switch installed – are you seeing any of these issues?
@Eric_Inovelli
Thanks so much for the super fast reply (at 5pm on a Friday)
@EricM_Inovelli
Below is my Hubitat logs from one of the switches. I am not sure how useful it is since its a ton of stuff not really filtered down but maybe something will stand out.
dev:92020-07-17 04:55:02.629 pm warnKitchen - Over Sink: Disabling logging after timeout
dev:92020-07-17 04:48:55.132 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 13], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:48:54.943 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:48:54.878 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 3, scale: 0, size: 4, meterValue: [0, 0, 3, 225], rateType: 1, deltaTime: 0, previousMeterValue: [0, 0, 0, 0])
dev:92020-07-17 04:27:32.159 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 8], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:27:31.968 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:27:30.019 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep2
dev:92020-07-17 04:27:30.016 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:2)
dev:92020-07-17 04:27:29.650 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:2) 0
dev:92020-07-17 04:27:28.727 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:1, sequenceNumber:3) 0
dev:92020-07-17 04:27:28.610 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep1
dev:92020-07-17 04:27:28.607 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:1)
dev:92020-07-17 04:27:28.394 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:2) 0
dev:92020-07-17 04:27:28.126 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:2) 0
dev:92020-07-17 04:27:26.663 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:2) 0
dev:92020-07-17 04:27:26.652 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:2) 0
dev:92020-07-17 04:27:25.745 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:2) 0
dev:92020-07-17 04:27:25.692 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:2) 0
dev:92020-07-17 04:27:03.801 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 206], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:27:03.590 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:27:01.229 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:33) - ep2
dev:92020-07-17 04:27:01.223 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[33], res01:false, sourceEndPoint:2)
dev:92020-07-17 04:26:58.186 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:1, sequenceNumber:1) 0
dev:92020-07-17 04:26:57.800 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 96], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:26:57.584 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:26:55.690 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:58) - ep1
dev:92020-07-17 04:26:55.683 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[58], res01:false, sourceEndPoint:1)
dev:92020-07-17 04:26:52.339 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:0) 0
dev:92020-07-17 04:25:02.929 pm debugKitchen - Over Sink: VersionReport(zWaveLibraryType:3, zWaveProtocolVersion:7, zWaveProtocolSubVersion:13, applicationVersion:1, applicationSubVersion:31)
dev:92020-07-17 04:24:40.976 pm debuglocked by:
dev:92020-07-17 04:21:38.245 pm errorjava.lang.NullPointerException: Cannot invoke method and() on null object on line 461 (firmwareStore)
dev:92020-07-17 04:21:38.227 pm infofirmware total bytes: 0
dev:92020-07-17 04:21:38.226 pm infoSorted all the bytes. cleaning up some memory…
dev:92020-07-17 04:21:38.024 pm debugpacking all the bytes…
dev:92020-07-17 04:21:36.661 pm debugfirmwareMdReport: checksum 0 firmwareId: 3585 manufacturerId: 798 maxFragmentSize: null firmwareTargets: 0
dev:92020-07-17 04:21:36.658 pm debugFirmwareMDReport: FirmwareMdReport(manufacturerId:798, firmwareId:3585, checksum:0, firmwareUpgradable:false, numberOfTargets:0, maxFragmentSize:null, firmwareIds:)
dev:92020-07-17 04:21:36.331 pm infoVersionReport- applicationVersion:1.31
dev:92020-07-17 04:21:36.329 pm infoVersionReport- zWaveProtocolVersion:7.13
dev:92020-07-17 04:21:36.041 pm infoFirmwareUpdateMd version:5
dev:92020-07-17 04:21:27.253 pm infoVersionReport- applicationVersion:1.31
dev:92020-07-17 04:21:27.251 pm infoVersionReport- zWaveProtocolVersion:7.13
dev:92020-07-17 04:20:24.140 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep2
dev:92020-07-17 04:20:24.137 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:2)
dev:92020-07-17 04:20:24.069 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep1
dev:92020-07-17 04:20:24.064 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:1)
dev:92020-07-17 04:19:01.977 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep2
dev:92020-07-17 04:19:01.973 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:2)
dev:92020-07-17 04:19:01.904 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep1
dev:92020-07-17 04:19:01.900 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:1)
dev:92020-07-17 04:14:49.715 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 8], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:14:49.539 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:14:47.523 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep2
dev:92020-07-17 04:14:47.517 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:2)
dev:92020-07-17 04:14:46.441 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep1
dev:92020-07-17 04:14:46.437 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:1)
dev:92020-07-17 04:14:44.535 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:1, sequenceNumber:17) 0
dev:92020-07-17 04:14:43.461 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:16) 0
dev:92020-07-17 04:13:58.710 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 210], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:13:58.534 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:13:56.476 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:33) - ep2
dev:92020-07-17 04:13:56.471 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[33], res01:false, sourceEndPoint:2)
dev:92020-07-17 04:13:53.491 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:1, sequenceNumber:15) 0
dev:92020-07-17 04:13:52.837 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 96], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:13:52.658 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:13:50.196 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:58) - ep1
dev:92020-07-17 04:13:50.192 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[58], res01:false, sourceEndPoint:1)
dev:92020-07-17 04:13:47.192 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:14) 0
dev:92020-07-17 04:12:19.128 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 8], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:12:18.955 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:12:16.504 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep1
dev:92020-07-17 04:12:16.500 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:1)
dev:92020-07-17 04:12:13.495 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:13) 0
dev:92020-07-17 04:12:12.020 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 96], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:12:11.840 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:12:09.779 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:58) - ep1
dev:92020-07-17 04:12:09.776 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[58], res01:false, sourceEndPoint:1)
dev:92020-07-17 04:12:06.789 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:12) 0
dev:92020-07-17 04:11:47.102 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 8], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:11:46.915 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:11:45.063 pm debugKitchen - Over Sink: SwitchMultilevelReport(value:0) - ep2
dev:92020-07-17 04:11:45.059 pm debugKitchen - Over Sink: MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:38, destinationEndPoint:0, parameter:[0], res01:false, sourceEndPoint:2)
dev:92020-07-17 04:11:42.072 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:1, sequenceNumber:11) 0
dev:92020-07-17 04:11:31.676 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 118], rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:11:31.495 pm debugKitchen - Over Sink: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: , rateType: 1, deltaTime: 0, previousMeterValue: )
dev:92020-07-17 04:11:29.096 pm debugKitchen - Over Sink: CentralSceneNotification(keyAttributes:0, sceneNumber:6, sequenceNumber:10) 0
I don’t think @Eric_Inovelli has slept since the release of these.
@Eric_Inovelli
@EricM_Inovelli
Haha :grin: Just to be clear — My problems can wait for next week!!! Have a :beer: and a good weekend!!!
giphy (4)
Yeah pretty much lol
Starting to feel survivors guilt…
No! I am not seeing/having any of these issues. I am using the current FW, the latest driver and the Hampton Bay Fan child (for the fan).
I did notice one thing, scrolling through this thread, @EricM_Inovelli suggested to set the local protections to “None”
However, mine is set as follows:
I can’t imagine it’s not just defaulting to “None”…
I’m installing my second switch tomorrow. So we’ll see…
Hmmm… Try setting the light back to the “Generic Component Dimmer”. I think the recommendation was to Only change the Inovelli Fan child to the “Hampton Bay Fan Component”.
Thank you that resolved my issue.
I am not 100% sure but the firmware update from this thread
May have fixed my issues. I only did it a few minutes ago but things are playing much nicer. It will be a day or so before I am sure but I will repost if I need anything else… Thanks again
Yeah, there have been a lot of success stories with this firmware. Please let us know how it goes.
As of 7pm tonight all is still working well…
I have been having this happen on its own periodically. I’m sure there is something being pushed orrran too quickly or in a specific sequence that is turning off the local control. In the past, I would exclude and re-include the device to fix it. Now that I know to look at the ‘disable local control’ that might save me some heartache and time.
