When I go to switch settings for the master switch and set the parameters for the notifications (Color, level, duration, and effect) It does not create the notification in devices like it does on the red series dimmers. Not sure what I am missing. Running the latest firmware and the latest device handlers. Is there somethin extra that need to be done to create them on this switch?
Just a shot in the dark (and I don’t have a LZW36), but did you originally include with an older DH and then update the DH? I had the same issue with dimmers. The notification would work, but there was no child device to allow you to turn it off manually. I had to exclude and then re-add to get the child objects created.
