I have an automation for my LZW36 using the cree8 blueprint (cree8/zwave-js-inovelli-lzw36-fan-switch-dimmer.yaml)
I just noticed that I get a warning everytime I turn the fan on because I use the speed argument (low, medium, high):
Calling fan.turn_on with the speed argument is deprecated, use percentage or preset_mode instead
It doesn’t look like preset_mode has options available though. Will those be available in the future or are they available now and I’m missing something?
speed_list:
- 'off'
- low
- medium
- high
preset_modes: []
speed: 'off'
percentage: 0
percentage_step: 1.0101010101010102
preset_mode: null
friendly_name: Nursery Fan
supported_features: 1
Can you post up screenshots of your actions you are performing when a button is pressed? The blueprint doesn’t have any actual functions associated with it, it just connects the dots from a button event to an action you specify.
You want the button press event to be “Call Service” and then call “fan.set_percentage” service with 1 (breeze mode), 33 (low), 66(medium), or 100(high).
More info:
In addition, Zwave JS is in control of the device properties. It would be awesome if we could figure out how to get our “breeze” mode (1%) to become a preset_mode specific to the LZW36 properties that ZwaveJS passes to HA. Perhaps @blhoward2 could provide some insight into this functionality.
Thanks for the reply. I tried using the percentage, but found that when then using fan.decrease_speed using the percentage step of 33, the math wouldn’t always work out - sometimes it would go from ‘medium’ straight to ‘off’. Same with fan.increase_speed. I unchecked the percentage step option and went back to using the speed setting and it works great, aside from the warnings in the logs.
How would I go about setting up the preset_modes or is that something one can’t configure?
