I will be adding Color control, but I will be doing it through child devices since their are two separate LED bars to change color on. Also, still working on the best way to do breeze mode through the SmartThings app, but currently if you set the level of the fan to 1% it will enable breeze mode. Double tap the fan up button on the switch will enable it as well.
