I’ve been experiencing this for a while.
- I turn the lights on.
- Dim the lights to whatever level, lets say 22%.
- Turn the lights off.
- Turn it on again, It goes to 100% and then comes back to 22%, giving this annoying flashing effect.
The above is the same if all done directly in the switch, hubitat app or a combination of both.
Firmware is 1.36
Feit LED light bulb.
Hubitat platform version 2.2.7.126
Driver Inovelli Fan + Light LZW36 2021-05-26
Parameters 12 and 13 are set to 0:.
This is what was logged when I pressed the on button in Hubitat, at which point it turned on at 100% and immediately went down do 22%.
dev:3092021-06-08 12:42:55.163 am debugMaster Bedroom Fan/Light Switch: MeterReport(meterType: 1, precision: 1, scale: 2, size: 4, meterValue: [0, 0, 0, 62], rateType: 1, deltaTime: 0, previousMeterValue: [])
dev:3092021-06-08 12:42:52.390 am debugMaster Bedroom Fan/Light Switch: SwitchMultilevelReport(value:22) - ep1
dev:3092021-06-08 12:42:52.382 am debugMaster Bedroom Fan/Light Switch: MultiChannelCmdEncap(bitAddress:false, command:1, commandClass:108, destinationEndPoint:0, parameter:[42, 3, 38, 3, 22], res01:false, sourceEndPoint:1)
dev:3102021-06-08 12:42:50.189 am debugon()
