I have one of these bulbs that has recently been very slow to transition. I mean minutes! At first I thought it wasn’t responding at all. But I just realized its just moving at an imperceptible rate. It used to work fine and the other bulb I have is still fine. How do I get it to speed up?
Recommend updating to the latest firmware. Also which hub you using? Edit, looks like HA.
I’ve already tried that firmware update with no luck. I’m using OZW on HA
There are issues that are fixed in Fix ozw dimming duration by firstof9 · Pull Request #38254 · home-assistant/core · GitHub, but they are waiting to merge them.
