LZW42 with Vera?
Hi there, I’ve got a couple Inovelli products in my Z-wave lineup already (some of the outdoor plugs that seem to be discontinued – but they’re rock solid!), and I’ve just got a couple of the new RGBW bulbs. I use a Vera hub along with Home Assistant, and it’s been great for me for years. But when I join the LZW42s all I get is colorless bright-white dimmable bulbs.
I’ve gone to www.inovelli.com/lzw42/setup as mentioned in the instructions, but that URL is dead. Is there any way for me to get RGB to actually be enabled via Vera? I tried adding parameters but their UI isn’t great and I ended up having to factory-reset the bulbs to undo my attempts. Any help is appreciated. Thanks!
Hey @zacs
Helping another Inovelli community member with a question about the LZW42 bulb and RGB setup and came across your post.
Please check out this tip posted by Eric and see if it helps with your setup.
Thanks,
Nate
Smart Home Specialist | Inovelli
Community | Support | Shop
Thanks @anon640257! I had actually asked this on the Vera community and got a similar answer. It looks like actually using D_DimmableRGBLight2 allows you to retain the white temperature values.
In the end, I was seeing some serious lag with Inovelli bulbs on Vera, and ended up moving all 60 or so Z-Wave device to zwave2mqtt with an Aeotec stick. I have been very happy with it – my bulbs are all lightning fast now. I used the manual setup described here to do so, which works super well.
Glad to here you were able to find a solution and thanks for sharing your findings here for the rest of us :grin::+1:
