Can anyone vouch for this?
Zwave JS Beta works for configuring parameters
Uh oh, cant set parameter 16 past 83823359, yet anyrthing using PULSE effect is higher than that and wont work. @Petro would this be a zwave_js bug report?
Are you using the correct mask with the call? Whatâs that log coming from, doesnât look like HA
Ah ok, that info comes from the âdriversâ or machine files. If you use numbers lower than that, does it work?
Yah anything under that 83823359 works
Iâm having trouble locating the spec sheet for that param to verify the bytes.
A very âroughâ explanation is in the actual manual. But nothing explaining the bytes.
EDIT: I guess it doesnât really matter because byte 4 is duration and 255 is infinite so the limit for that value should be 4294967295
EDIT2: So hereâs the conundrum⌠ZwaveJS does not have the ability to set multiple byte masks at the same time, same with home assistant. If I were to change this, the zwave_js gentlemen would want me to make it a partial parameter. Effectively making it impossible to set through the native HA service. Youâd have to use the MQTT bridge to do the setting.
I know @EricM_Inovelli had a google sheet somewhere, but I cant find now. @nathanfiscus made the toolbox that gives me the number so he must know the logic behind it
Hmmm so really even with the explanation it seems like it wont really help if Im understanding you.
well, you can get around it by using the MQTT set sendcommand call but itâs not easy to understand. Thatâs what I currently do for the LZW45. Setting the partial params all at once is coming but the ETA is unknown. It only seems to affect inovelli devices because the params reset to zero when you provide invalid settings.
Yes, thatâs because those parameters do not accept partials. You can only set the entire parameter or nothing. So when ZwaveJS2MQTT separates them into the individual bitmasks, it doesnât work because a partial byte sent to the device sets the full parameter to zero. I donât know why inovelli does this but they do. My guess is that they want you to set the entire parameter so that you donât get any goofy behavior when setting each bytemask in between.
To set the full parameter, I use the following script:
zwavejs2mqtt_mqtt_set_config_parameter:
alias: Set Config Parameter to ZwaveJS2MQTT via MQTT
description: Publishes to ZwaveJS2MQTT
fields:
node_id:
description: Zwave Node Id
example: 3
parameter:
description: Parameter to be set.
example: 4
value:
description: Value to be set for the parameter
example: 256
bytes:
description: Size of parameter (1, 2, or 4)
example: 4
variables:
payload:
args:
- nodeId: "{{ node_id }}"
commandClass: 112
property: "{{ parameter }}"
- set
- "{{ [ parameter, value, bytes ] }}"
sequence:
- service: mqtt.publish
data:
topic: zwave/_CLIENTS/ZWAVE_GATEWAY-Mosquitto/api/sendCommand/set
payload: "{{ payload | tojson }}"
If you look at my current github configuration, I have a whole set of scripts that handle all my lzw45s but it requires you to keep the MQTT connection. So right now, I use websockets (Zwave JS Integration) for my devices, and I send the commands to the MQTT server.
So would I use that entire script to set just ONE of the FOUR parameters I need to set? So in the end, I would be running the script 4 times?
So parameter 22. Toolbox says to set it to 48, so using your script, I would have
fields:
node_id: 11
example: 3
parameter: 22
example: 4
value: 48
example: 256
bytes: 4
example: 4
variables:
payload:
args:
commandClass: 112
- set
sequence:
data:
Add the script I posted to your scripts and the service call would just be:
- service: script.zwavejs2mqtt_mqtt_set_config_parameter
data:
node_id: 11
parameter: 22
value: 48
bytes: 4
Oh, gotcha. Iâve never used scripts before. I will give that a try. Thanks
So is your script setting the parameters via MQTT or natively through HA?
Your using ZWAVEJS2MQTT add-on with the Z Wave JS intergration but your NOT pointing the integration to the mqtt add-on as described in the config?
Iâm pointing the Zwave JS integration at ZwaveJS2MQTT on port 3000. Turned off âDisable MQTT Gatewayâ. But I do not have MQTT discovery set to discovery ZwaveJS2MQTT so I only get entities from Zwave JS Integration. I use the MQTT Gateway to send the configuration parameters. Itâs a very odd setup. You need to latch ZwaveJS2MQTT to an MQTT server by filling out the MQTT information in ZwaveJS2MQTT.
For a premade script like that, in the upper right corner of add a script, thereâs 3 dots. Click it and edit as yaml. Paste the script I wrote but do not include the first line (zwavejs2mqtt_mqtt_set_config_parameter:), just include everything else and then save.
Alright I did that. It named your script some random numbers for some reason, but whatever. So go to dev tools and run the service, as show in picture. I see the data come across MQTT.
But then when I tried to change the arguments to this, it doesnt change anything according to my MQTT browser. But the timestamp is updating to the time that I called the service.
