Matter light switch with Govee matter fan and light combo
Hi all,
Wondering if anyone knows if this combination will work with the assistance of home assistant set up? I want to be able to control them separately with button pushes but not sure if this will work?
Thanks all
If you can connect them both to HA, then you can control one with the other…
The issue that usually crops up though is if you want smooth dimming of lights, you need some way to pair or bind the switch and light together without using HA as the middle man.
On, Off and speed selection based on button presses are easy enough to add automations for though.
Thanks for the insight I will be adding and playing around this weekend. So we will see what happens. Again thanks for the reply.
Highly recommend this blueprint. It’s what I’ve used with this exact setup.
I appreciate the link but it isn’t available? Would be interested in it if you can attach link.
Thank you
While I am sure @ithinkmaybethis will also likely get around to fixing the link, I am assuming this is what they were trying to share based on some manual editing of the provided link…
That’s the one!
