Missing Children … Devices
I have a bunch of VZW31-SN dimmers where I am trying to replicate the functionality of setting colour bar temp based on outdoor temp. I was using child devices before, but these are not available in newer drivers.
This was my RM code:
Trigger Events: Temperature of Weather *changed*
IF (Temperature of Weather) >= 32 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 2 -> Sat 100
ELSE-IF (Temperature of Weather) >= 24 AND <32 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 11 -> Sat 100
ELSE-IF (Temperature of Weather) >= 18 AND <24 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 22 -> Sat 100
ELSE-IF (Temperature of Weather) >= 12 AND <18 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 33 -> Sat 100
ELSE-IF (Temperature of Weather) >= 7 AND <12 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 44 -> Sat 100
ELSE-IF (Temperature of Weather) >= 0 AND <7 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 55 -> Sat 100
ELSE-IF (Temperature of Weather) >= -6 AND <0 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 66 -> Sat 100
ELSE-IF (Temperature of Weather) >= -15 AND <-6 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 77 -> Sat 100
ELSE-IF (Temperature of Weather) >= -30 AND <-15 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 83 -> Sat 100
ELSE-IF (Temperature of Weather) > -40 AND <-30 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 92 -> Sat 100
ELSE-IF (Temperature of Weather) <= -40 THEN
	Set color: Inovelli Dimmer (Child LED Device) -> Custom Color -> Hue 98 -> Sat 100
END-IF
I do see an option to set a custom action in RM that changes LED colour, but this activator has multiple fields. RM only allows setting one for a string or number, or I just can’t wrap my head around the metaphor of how to set that field from RM.
The child devices were so handy before.
RM does allow for setting multiples together – the general gist of how to do it is in the “Using Rule Machine” portion of this article.
In the Hubitat community, there have been quite a few posts over the years about setting up and managing the 2-1’s LEDs (more about the Blues since they came out first, but AFAIK, LED mgmt is the same as Reds) – searching that community should yield some good “ledEffectOne” and “ledEffectAll” examples and info.
Had me in the first half not gonna lie
