I’m trying to setup a VZM32-SN mmWave dimmer with Home Assistant. It mostly works OK. However, trying to set the mmWave areas through the Zigbee2MQTT interface when I click ‘Apply’ I get the error:**
Living Room Main Light/set(mmwave_detection_areas): Parameter 'xMin' is missing
I’m not sure whether this is an Inovelli, HA or wetware issue, but would appreciate a solution. Thanks.
