Multi-Way 2x Red Switches with Homey
Hi all,
I got 2 Red Dimmer Switches I’m trying to place on the same 3-way circuit to be used as on/off switches. Double checked the wiring and one switch controls the lights as expected and one doesn’t do anything when pressed, but is powered on and connected. From the wire diagrams this is the line/load in separate junction boxes with neutral diagram
In Homey I have the node ID’s for the corresponding switches in group 2, but the switches are not talking to each other. Is there something else I’m missing or another setting that needs to be changed? If there’s also a direct guide on how to do this on Homey that would be great as I haven’t been able to find any documentation for Homey yet.
Some other information - the switches are around 10 feet away from each other with only 1 non insulated wall between. Both show up as authenticated in Homey.
