I’ve installed the inovelli driver and set up rules in rule machine but debug logs show “Switch Multilevel report received with value of off (0)” rather than button 1 push or button 1 held. why are the button pushes only showing up as level sets or alternatively how do I make rules for this?
ABC controller is probably your best route, here are the maps for button push/held events:
And no, they do NOT correspond to an actual push or hold of the toggles. It makes more sense when you see the context/background, but that should be enough to get you fixed up.
