New problem with an Inovelli Red
So I recently noticed my innovelli Red I purchase probably a few years ago that is now showing up as dead in HA (Home Assistant). I did kill power to look at the switch wiring, and some how the wire backed out of the switch, not sure why that happened. After I redid the switch wiring it is still showing as dead. The LED strip is not even working at the moment. So for some reason no power is getting to the Lights connected to it. I am not sure if my switch itself had died or if something else is going on.
Have you tested the line hot to make sure it’s live?
Once I determine the better way to test the wiring I can do that, though it would seem odd that electrical wiring would stop moving power all of a sudden.
Ended up finding out the Switch itself stopped working. Since power was still live in the wires. Not sure what happened with the switch.
