Newbie trying to configure RED dimmer mutli tab functions
@Somu - Negative as long as the rule is generated and the devices are selected for what is turned off. For your other devices, did you select the correct Inovelli Driver for those devices as well?
all have the correct drivers … and all are identical switches
here is screen shot of rule
Okay, So I’m going to go through this with multiple screen shots. Follow each screen shot with me. We’re going to delete your “GD” rule and make a new one.
Let’s start again. Rule Machine -> Create New Rule
Select Trigger Events
Select Button
Select device you want to control from.
Change tap number and PUSH for UP.
Select Done with the Trigger Event
Select Done with Trigger Event (again)
Select Actions to Run
Select Control Switches, Push Buttons
Select Turns Switches off
Select the switch you want to control (include the switch you’re using if wanted)
Select done with this action
Select Done with Actions
Select “Done” to finish and save
@somu did you ever get the multi tab commands to show up in you device detail. I have the same issue. Just bought the red series dimmers and I cant see those commands on the device page. I have verified that the drivers @harjms pointed out were loaded but still done see them. I was about to go into rule machine to create a rule but realized my mutli tap commands were still not present.
