A year or so ago I bought a 10 pack of inovelli red dimmers and a few red switches. I’ve installed a bunch of them throughout the house with no problems. Yesterday I installed 2 more (one dimmer, one switch) and cannot get the scenes to be recognized in home assistant. I’m seeing this log when pressing the config button:
2021-07-16 10:05:25.978 Detail, Node020, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x14, 0x05, 0x5b, 0x03, 0x2a, 0x80, 0x03, 0x10
2021-07-16 10:05:25.978 Info, Node020, Received Central Scene set from node 20: scene id=3 in 7680 seconds. Sending event notification.
2021-07-16 10:05:25.978 Warning, Node020, No ValueID created for Scene 3
I assume the no ValueID created for Scene 3 is the issue.
When looking around, I’m seeing a lot of advice related to changing config files, but I don’t really want to do that since other “identical” switches are working just fine and I don’t want to break their functionality.
I looked into upgrading to the newer JS version a week or so ago but the docs made it sound like if I didn’t have a problem I didn’t need to… Maybe this is the problem that makes me need to? haha
Zwave JS is definitely “THE” path forward. I would recommend upgrading. Z-wave you will need to make config file changes and other hassles (and it’s not actively being supported very much anymore).
This seems to have worked. I followed this guide to migrate:
And now I’m seeing “zwave_js_value_notification” events being fired when activating scenes on all of my switches (instead of zwave.scene_activated).
It will take a little time getting everything running again as it looks like now instead of using the 4 digit “scene data” number that I had been using (IE: double click a button = 7860) . I now use a more readable “value: KeyPressed2x”.
So far everything with zwave js seems to make more logical sense, so thats good, but it’ll take a little bit of time to just get everything moved over and working again.
Thanks! Definitely feels like the right move to have upgraded.
O_O I was literally JUST starting to tackle bulk notifications last week and started to write some functions to do that for me instead of copy/paste 20 times. What great timing!
