No configuration options when connecting switch
Hey all. Ive tried wiring this in 2 different places. Reset multiple times, and I have no idea whats going on. All the other switches work fine, but this one has no configuration options. Please help!
What’s the firmware on the switch, and what version of HA are you running? If you hit the Zigbee info dropdown, can you share what it’s telling you under Quirk?
I’ve seen this occasionally when adding a new device where it may just take a little bit to show up in the frontend, but in case that’s not it, the other information should help narrow things down.
In the short term if there’s something specific you’re wanting to change, you should be able to hit those 3 vertical dots to the right of Reconfigure > Manage Zigbee Device > change the Clusters dropdown to InovelliVZM31SNCluster (Endpoint 1, Type In), and then change any of the attributes from there.
