Notification automation in HASS
I couldn’t find this anywhere else so I’ll ask here. I use homeassistant and I can change the led notification manually on the zwave config page. I can set the led color or intensity etc.. by changing the node config options in hass:8123/config/zwave. How can I create an automation that does this? e.g. if garage door is open led is red. Or even better when a scene is activated change the color of the led etc.
Thanks for any input or pointers in the right direction.
Have you seen this link?
That’s what I needed.
Thanks
