I get a text whenever that door is open, so I know the contact is working.
I deleted those routines and setup one on another door. When I have Main Room Lights turned off, everything is grayed out with all of the switches in the off position. Nothing happens when I open the door. With the Main Room Lights turned on, the lights, of course, come on, but there is no notification via the LED strip.
I understand what youâre saying â I really do. But, as shown by the 3rd and 4th screenshots, when I turn off Main Room Lights, everything else is grayed out and Iâm unable to do anything with any of them. How do I turn on Notifications when those controls are grayed out?
I really donât know any other way to explain this. You CANNOT have a âturn onâ or âturn offâ action in the same routine in which you are trying to set notifications. The third and fourth screenshots you pointed to where the notification actions are grayed out have a âturn offâ action, which exactly what I have been trying to get you to remove.
(If you have a âTurn Onâ action selected, you can set the notification parameters but nothing will work. If you have a âTurn Offâ action selected, the parameters below will be grayed out.)
1 - Click on the + to create the routine.
2 - Add the contact sensor as a trigger
3 - Click on the + in the Then section and select Control Devices
4 - Select the Inovelli you want the notificaiton on and press Next
5 - IN THE TOP SECTION, âTURN ONâ WILL BE SELECTED BY DEFAULT. PRESS âTURN ONâ ONCE TO DESELECT IT
6 - Select the four notification parameters
Not necessarily, but it depends upon how you want the operate the bulbs. If you just want to turn the bulbs on or off or set some dim levels, you can use the multi-tap capabilities of the Red. To do this you would configure the on/off and several dim levels using routines or scenes.
However, if you want to be able to dim up and down using the paddle just as if a dumb bulbs were wired to it, then you will need to use a Blue for that. Youâll need to use Zigbee binding to bind the switch to the bulbs.
They are RGBW bulbs on my front and back porches. I donât really see the need for anything other than on/off and maybe a little dimming at the local level. Anything more than that I can do via the app or Alexa. If I do decide I want more local control, I can always swap the switches out for Blue.
Research tells me that I do it by creating scenes (as you mentioned). I havenât had a chance to try that yet, but I should be able to within the next couple of days.
Got everything working as routines. Thanks again for your help, Bryan. The crazy part about this stuff is once you get going, you gotta get more stuff. Already decided I need at least 1 more Red switch.
