On/off ramp versus double tap ramp
Good evening!
I have two Blue dimmer switches controlling dumb track lights. Switch 1 provides the hot/load for the lights. Both switches are Zigbee bound with on/off and dimmer level.
The lights fade on/off. I’d prefer them to be instant on/off. So, I set the ramp ramp rates for local AND remote (because of the binding) to zero. Indeed, this stop the lights from fading on/off.
However, my double tap events (for min and max brightness) are now instant also. I was surprised by this because I had assumed the double tap events would respect the Dimming Speed Up/Down parameters (which were left at default).
Is the ramp rate for double tap for min/max brightness tied to the ramp rate for on/off?
Thank you!
