I’ve had a red series on/off switch working perfectly with HA and ZWaveJS for a couple of months. A couple of days ago I noticed it was reported as Dead in ZWaveJS.
I tried to ping, re-interview it, and pulled the air gap . I was able to exclude and re-add it back but it is still failing interview/ping.
I’m running ZWaveJS
Driver Version: 7.7.1
Server Version: 1.7.0
Any hints/tips would be appriciated
Here are some logs
2021-06-06T20:36:13.576Z SERIAL « [ACK] (0x06)
2021-06-06T20:36:13.587Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-06T20:36:13.588Z SERIAL » [ACK] (0x06)
2021-06-06T20:36:13.589Z DRIVER « [RES] [SendData]
was sent: true
2021-06-06T20:36:13.715Z SERIAL « 0x01180013c100000d00c77f7f7f7f0101060000000002030000f8 (26 bytes)
2021-06-06T20:36:13.716Z SERIAL » [ACK] (0x06)
2021-06-06T20:36:13.718Z DRIVER « [REQ] [SendData]
callback id: 193
transmit status: OK
2021-06-06T20:36:13.739Z SERIAL « 0x011000040016087205031e00020001c7005b (18 bytes)
2021-06-06T20:36:13.742Z CNTRLR [Node 022] [+] [Manufacturer Specific] manufacturerId: 798 [Endpoint 0]
2021-06-06T20:36:13.745Z CNTRLR [Node 022] [+] [Manufacturer Specific] productType: 2 [Endpoint 0]
2021-06-06T20:36:13.748Z CNTRLR [Node 022] [+] [Manufacturer Specific] productId: 1 [Endpoint 0]
2021-06-06T20:36:13.750Z SERIAL » [ACK] (0x06)
2021-06-06T20:36:13.752Z DRIVER « [Node 022] [REQ] [ApplicationCommand]
└─[ManufacturerSpecificCCReport]
manufacturer id: 0x031e
product type: 0x02
product id: 0x01
2021-06-06T20:36:13.757Z CNTRLR « [Node 022] received response for manufacturer information:
manufacturer: Inovelli (0x031e)
product type: 0x02
product id: 0x01
2021-06-06T20:36:13.759Z CNTRLR [Node 022] [+] [Manufacturer Specific] interviewComple [Endpoint 0] [internal]
te: true
2021-06-06T20:36:13.784Z CNTRLR [Node 022] Interviewing Version...
2021-06-06T20:36:13.785Z CNTRLR » [Node 022] querying the CC version for Version...
2021-06-06T20:36:13.796Z SERIAL » 0x010a0013160386138625c207 (12 bytes)
2021-06-06T20:36:13.797Z DRIVER » [Node 022] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 194
└─[VersionCCCommandClassGet]
CC: Version
2021-06-06T20:36:13.799Z SERIAL « [ACK] (0x06)
2021-06-06T20:36:13.809Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-06T20:36:13.810Z SERIAL » [ACK] (0x06)
2021-06-06T20:36:13.811Z DRIVER « [RES] [SendData]
was sent: true
2021-06-06T20:36:17.973Z SERIAL « 0x01180013c20101a1007f7f7f7f7f0101070000000002040000e9 (26 bytes)
2021-06-06T20:36:17.975Z SERIAL » [ACK] (0x06)
2021-06-06T20:36:17.976Z DRIVER « [REQ] [SendData]
callback id: 194
transmit status: NoAck
2021-06-06T20:36:17.982Z CNTRLR [Node 022] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2021-06-06T20:36:18.489Z SERIAL » 0x010a0013160386138625c207 (12 bytes)
2021-06-06T20:36:18.491Z DRIVER » [Node 022] [REQ] [SendData]
│ callback id: 194
CC: Version
2021-06-06T20:36:18.494Z SERIAL « [ACK] (0x06)
2021-06-06T20:36:18.505Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-06T20:36:18.506Z SERIAL » [ACK] (0x06)
2021-06-06T20:36:18.507Z DRIVER « [RES] [SendData]
was sent: true
2021-06-06T20:36:22.607Z SERIAL « 0x01180013c201019b007f7f7f7f7f0101070000000002040000d3 (26 bytes)
2021-06-06T20:36:22.609Z SERIAL » [ACK] (0x06)
2021-06-06T20:36:22.610Z DRIVER « [REQ] [SendData]
callback id: 194
2021-06-06T20:36:22.616Z CNTRLR [Node 022] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2021-06-06T20:36:23.123Z SERIAL » 0x010a0013160386138625c207 (12 bytes)
2021-06-06T20:36:23.125Z DRIVER » [Node 022] [REQ] [SendData]
│ callback id: 194
CC: Version
2021-06-06T20:36:23.128Z SERIAL « [ACK] (0x06)
2021-06-06T20:36:23.138Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-06T20:36:23.139Z SERIAL » [ACK] (0x06)
2021-06-06T20:36:23.141Z DRIVER « [RES] [SendData]
was sent: true
2021-06-06T20:36:27.212Z SERIAL « 0x01180013c2010198007f7f7f7f7f0101070000000002040000d0 (26 bytes)
2021-06-06T20:36:27.213Z SERIAL » [ACK] (0x06)
2021-06-06T20:36:27.214Z DRIVER « [REQ] [SendData]
callback id: 194
2021-06-06T20:36:27.220Z CNTRLR [Node 022] Node 22 did not respond after 3 attempts, it is presumed dead
2021-06-06T20:36:27.222Z CNTRLR [Node 022] The node is now dead.
2021-06-06T20:36:27.228Z CNTRLR [Node 022] Interview attempt (8/5) failed, node is dead.
2021-06-06T20:36:33.086Z SERIAL « 0x0112000400140a32022134000000080000ca0010 (20 bytes)
2021-06-06T20:36:33.087Z CNTRLR [Node 020] [~] [Meter] value[66049]: 0.8 => 0.8 [Endpoint 0]
