I have an open Zwave home assistant setup, I currently only see the following entitiy for my Inovelli Light Switch-
light.lzw31_dimmer_level
I believe that there should also be a switch entity within home assistant so I can utilise single, double and triple taps on the switch, using the following blueprint
However I do not appear to have any switch entities listed,
Can anyone advise on what I should do, note I havent made any config changes in my home assistant at this time and this is where I believe I am stumbling.
