Paddle on smart dimmer (2-in-1 switch) with canopy module turns on both lights and fan
Hi,
I have the smart dimmer (2-in-1) switch as well as the canopy module.
The 2-in-1 switch looks like its on firmware 2.18
I setup the switch to use Method #2: Dual Zigbee Bindings from (Setting Up Your Blue Series Fan/Light Canopy Module With an Inovelli Switch • SmartThings | Inovelli Help Center)
I setup the paddle on the switch to control the lights on the canopy module and I setup the favorite/config button to control the fan.
When I press the paddle up or down, it operates the lights, but also operates the fan. When i press the config/favorite button, it correctly operates the fan at multiple speeds depending on the number of presses
What did I do wrong with the setup with the paddle operating both? I would like the paddle to just operate the lights.
on the smart switch:
bind #5 is set to 2/EUI/1
bind #6 is set to 3/EUI/2
258. switch mode is set to dimmer
any ideas?
Thanks
Mike
