Pairing failing for dimmer / fan control but works for switch (matter/AppleTV)
Am trying Inovelli and purchased three switches (on/off, dimmer and fan). The on/off paired and is working without trouble but the pairing fails on the dimmer and fan switches. Matter setup, trying pairing with the Apple Home app → add accessory), verified iPhone, iPad (tried both) are on same network as AppleTV (which listed as the hub). Both switches enter pairing visibly but after a long time out - I get the pairing failed dialog. Have tried the pairing in the same location as the working on/off inovelli switch - no joy. Is there any debugging on what is failing?
