Parameter 261 - Relay Click Sound (On/Off Mode)
I have two blue series (VZM31-SN) set up as a 3-way. I completed the zigbee binding and the switches are working fantastic. My wife now would like the relay sound turned off. I’m using Home Assistant with ZHA. I can’t figure out how to change Parameter 261 - Relay Click Sound (On/Off Mode). I’ve gone into the Manage Zigbee Device area, set the Cluster to Inovelli from the drop-down menu. I then go to Attributes and try and set relay_click_in_on_off_mode and write 1 as the value but the sound still stays on. I am using the switches in on/off mode, not dimmer mode.
Any ideas on what I’m doing wrong so I can update this parameter?
I’ve also tried using the toggle under Configuration and just can’t get anything to work. I have other switches were this works fine. Is it because the switches are in three way dumb mode?
My understanding is that in a 3 way setup, the relay is required for the switch to function. You wouldn’t be able too disable it.
That would explain it
This wouldn’t be applicable for a three way using two blue series switches (binding). The relay click is required for folks using Smart+Dumb switch setup. For those configured in a Single, 3-way with Aux, 3-way with bindings, the user should be able to disable the relay click.
Most likely the reason. You should be able to configure the switches as single way mode.
Boom! Put them both as single pole and the problem is solved! Thanks!
