Parameter naming convention
Note: the naming convention for the parameters is nonexistent / really confusing. Here is an example:
in table: Param 50 : Button Press Delay
in text: Param 50 : Switch Delay
in home assistant(ZHA): button_delay (0x0032)
I’m glad there is at least the HEX parameter value in Home Assistant; otherwise, I would doubt every change I need to make. For now, with the mmWave blue series, it seems Parameters are the only way to configure the switches. I would at least suggest having the same naming scheme across the board to alleviate part of the config pain. (When comparing to the other blue series)
