Possible to automate LED Indicator Intensity on White Series?
@harryh
A request if you can help …
Parameter 106 (more specifically, attribute 0x00122f0106 of the custom cluster), is to enable / disable the very annoying feature whereby double-tapping on the “Config” button turns off notifications. Currently, this is set to “On” by default and there is no practical way to turn it off. Can you add this additional parameter to your custom cluster submission that you made to Home Assistant?
This is really one of those “features” that, IMO, should be removed entirely from the devices since it would be better for the hub to be sent the double-tap and decide to turn off the notification. As it is now, this feature just interferes with the ability to use double-tap on the Config button.
