Problems setting the LED Strip color
I got this when I put “67” in the Hue setting box and clicked the button (in the Device page):
And, I can’t figure out how to send the parms to the “setColor” command.
AND, when I tell the Hubitat to set the color to “White” it comes out yellow (using the “bulb” device’s “set color and level”).
The only way to get white seems to be calling the custom “setColorTemperature” action–and it needs a value, but ANY value you put in there makes it white.
It’s been tough trying to figure this out, as most of the parameters aren’t working like you’d expect.
This came from the factory with v1.47 and I updated to 1.48 for the base device (as the LED patch didn’t seem to be needed).
What’s the date on the Inovelli driver?
There was a fix to the Inovelli drivers on August 25 to address the LED color issue. Take a look in the driver comments:
https://raw.githubusercontent.com/InovelliUSA/Hubitat/master/Drivers/inovelli-dimmer-red-series-lzw31-sn.src/inovelli-dimmer-red-series-lzw31-sn.groovy
Date: 2020-09-16
For other colors, this has been working for me
It seems to work for some colors better than others.
Interesting… I’m having similar problems with my lzw31 black dimmer using the hubitat rule machine.
I’m on firmware 1.57 and using the Inovelli latest driver.
If I use set color command on the LED color child instance it seems to work properly with the hubitat rule manager for green, blue, and a few others I tested. But set color = white results in the led showing yellow and changes the switch config parameter for custom led rgb value to 40. Doesn’t make sense to me…
Update… If I follow the recommendation of @robstitt and set color temp to any value for the lzw31, it results in a white led. This solves my problem but seems like the switch should properly set the led color = white when commanded by the set color switch.
