Question about Red Series Smart Presence Dimmer
I’ve successfully installed the switch and paired it with my Hubitat controller. The switch turns on the light when it senses motion without having to create a rule. There have been times when I had the lights turn on with motion but did not keep moving so the lights turned off. Does anyone know how to change the timer which turns off the light after no motion?
Try tweaking P114. According to the parameters documentation, that is the mmWave Hold Time. (The same parameter on the Blue mmWave Fan Switch is called mmWave Time Out, so you may see that parameter labeled as either.) :man_shrugging:
I completely missed that parameter… thanks!
