Question around Max Dim
I have a couple of red series dimmers that require me to set Max Dim Level to 85(%) due to the type of bulbs per troubleshooting issue here.
My question is - if Max Dim Level is set to 85% on the switch, when I’m writing automations in Home Assistant with service_data for brightness: 100(%) - is that 100% of 85%? Or is it over-riding the 85% max dim level setting on the switch?
Thanks
Yes. The Brightness levels take the min and max brightness into account in the firmware. If you set the min brightness to 35% and the max brightness to 85% then:
Dimming level 1% = 35% brightness
Dimming level 100% = 85% brightness
Awesome! Thank you.
