Red Dimmer Series switches unresponsive
A month has passed and all my Inovelli Red Dimmer switches have gone unresponsive AGAIN.
The rest of my Zwave devices rocksolid.
Setup:
  • Latest Homeassistant on a Raspberry PI.
  • HUSBZB-1 stick (only using Zwave).
  • 42 Zwave devices, 22 of them Inovelli Red Dimmer switches.
  • Latest version of Zwave-JS.
  • No power cuts.
Problem
  • All inovelli Switches are unresponsive at the switch and via HA.
  • to turn on a switch at the wall I need to tap the config 8 times.
  • Healing a single switch and the whole network complete, but do nothing.
  • Reinterviewing individual switches fail.
  • Connection checks between switches and HA instance all fail even right next to the Raspberry pi even though the inovelli switches are the devices bridgeing other zwave devices at distant regions of the property.
  • When this happened a month ago I excluded and included each switch and they worked fine.
Any tips?
Haven’t found anything drastic in the logs.
I just tried to update the firmware on a switch and it acted up and failed that update and that messed up the whole network until I air gapped and reset the rogue switch. Just saying, one bad device can screw them all up.
hmm. Any tips on finding a dead/rogue switch? Logs don’t point to any one device.
Not really, I knew which one to look at first.
I would like to try it again and see if there was a reason why it messed up the network. Check if it is spamming the network.
Can you perform a network heal and provide the debug-level log output in a quote here? We’ll get you sorted.
I have the same setup and my network is working great, so there is definitely something going on.
Have you tried powering everything off (turning off the breaker) and then back to on? I have seen switches spam the network in the past for no apparent reason. That fixed it for me.
part 1
Subscribed to Z-Wave JS Log Messages…
Log Level changed to: Debug
2022-02-04T03:08:05.279Z CNTRLR   starting network heal...
2022-02-04T03:08:05.282Z CNTRLR » [Node 001] requesting node neighbors...
2022-02-04T03:08:05.317Z SERIAL » 0x010700800100000079                                                 (9 bytes)
2022-02-04T03:08:05.322Z DRIVER » [REQ] [GetRoutingInfo]
                                    remove non-repeaters: false
                                    remove bad links:     false
2022-02-04T03:08:05.340Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:05.348Z SERIAL « 0x01200180000000000000005080404200000000000000000000000000000000000 (34 bytes)
                                  08c
2022-02-04T03:08:05.356Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:05.366Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 61, 63, 72, 79, 82, 87
2022-02-04T03:08:05.391Z CNTRLR « [Node 001] node neighbors received: 61, 63, 72, 79, 82, 87
2022-02-04T03:08:05.408Z CNTRLR   [Node 061] added to healing queue for listening nodes
2022-02-04T03:08:05.410Z CNTRLR   [Node 063] added to healing queue for listening nodes
2022-02-04T03:08:05.413Z CNTRLR   [Node 072] added to healing queue for listening nodes
2022-02-04T03:08:05.415Z CNTRLR   [Node 079] added to healing queue for listening nodes
2022-02-04T03:08:05.417Z CNTRLR   [Node 082] added to healing queue for listening nodes
2022-02-04T03:08:05.418Z CNTRLR   [Node 087] added to healing queue for listening nodes
2022-02-04T03:08:05.422Z CNTRLR   [Node 061] healing node...
2022-02-04T03:08:05.424Z CNTRLR » [Node 061] refreshing neighbor list (attempt 1)...
2022-02-04T03:08:05.464Z SERIAL » 0x010500483d62ed                                                     (7 bytes)
2022-02-04T03:08:05.467Z DRIVER » [Node 061] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 98
2022-02-04T03:08:05.473Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:05.562Z SERIAL « 0x010500486221f1                                                     (7 bytes)
2022-02-04T03:08:05.565Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:05.569Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   98
                                    update status: UpdateStarted
2022-02-04T03:08:09.200Z SERIAL « 0x010500486222f2                                                     (7 bytes)
2022-02-04T03:08:09.203Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:09.208Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   98
                                    update status: UpdateDone
2022-02-04T03:08:09.216Z CNTRLR « [Node 061] neighbor list refreshed...
2022-02-04T03:08:09.220Z CNTRLR » [Node 061] Deleting SUC return route...
2022-02-04T03:08:09.237Z SERIAL » 0x010500553d63f1                                                     (7 bytes)
2022-02-04T03:08:09.239Z DRIVER » [Node 061] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x3d63
2022-02-04T03:08:09.243Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:09.303Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:08:09.305Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:09.308Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:09.547Z SERIAL « 0x010500556300cc                                                     (7 bytes)
2022-02-04T03:08:09.549Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:09.552Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     99
                                    transmit status: OK
2022-02-04T03:08:09.566Z CNTRLR » [Node 061] Assigning SUC return route...
2022-02-04T03:08:09.582Z SERIAL » 0x010500513d64f2                                                     (7 bytes)
2022-02-04T03:08:09.584Z DRIVER » [Node 061] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x3d64
2022-02-04T03:08:09.589Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:09.924Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:08:09.927Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:09.929Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:10.720Z SERIAL « 0x010500516400cf                                                     (7 bytes)
2022-02-04T03:08:10.722Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:10.727Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     100
                                    transmit status: OK
2022-02-04T03:08:10.738Z CNTRLR » [Node 061] deleting return routes (attempt 1)...
2022-02-04T03:08:10.755Z SERIAL » 0x010500473d65e5                                                     (7 bytes)
2022-02-04T03:08:10.757Z DRIVER » [Node 061] [REQ] [DeleteReturnRoute]
                                    payload: 0x3d65
2022-02-04T03:08:10.762Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:10.766Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:08:10.768Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:10.771Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:08:10.982Z SERIAL « 0x010500476500d8                                                     (7 bytes)
2022-02-04T03:08:10.987Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:10.989Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     101
                                    transmit status: OK
2022-02-04T03:08:11.002Z CNTRLR » [Node 061] assigning return routes to the following nodes:
                                  1
2022-02-04T03:08:11.003Z CNTRLR » [Node 061] assigning return route to node 1 (attempt 1)...
2022-02-04T03:08:11.020Z SERIAL » 0x010600463d0166e5                                                   (8 bytes)
2022-02-04T03:08:11.022Z DRIVER » [Node 061] [REQ] [AssignReturnRoute]
                                    payload: 0x3d0166
2022-02-04T03:08:11.027Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:11.362Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:08:11.366Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:11.369Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:08:12.293Z SERIAL « 0x010500466600da                                                     (7 bytes)
2022-02-04T03:08:12.295Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:12.298Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     102
                                    transmit status: OK
2022-02-04T03:08:12.319Z CNTRLR   [Node 061] healed successfully
2022-02-04T03:08:12.321Z CNTRLR » [Node 061] requesting node neighbors...
2022-02-04T03:08:12.347Z SERIAL » 0x010700803d00000045                                                 (9 bytes)
2022-02-04T03:08:12.349Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:08:12.356Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:12.362Z SERIAL « 0x012001800000000000000000004c3000000000000000000000000000000000000 (34 bytes)
                                  022
2022-02-04T03:08:12.364Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:12.368Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 75, 76, 79, 85, 86
2022-02-04T03:08:12.380Z CNTRLR « [Node 061] node neighbors received: 75, 76, 79, 85, 86
2022-02-04T03:08:12.381Z CNTRLR   [Node 075] added to healing queue for listening nodes
2022-02-04T03:08:12.383Z CNTRLR   [Node 076] added to healing queue for listening nodes
2022-02-04T03:08:12.384Z CNTRLR   [Node 085] added to healing queue for listening nodes
2022-02-04T03:08:12.386Z CNTRLR   [Node 086] added to healing queue for listening nodes
2022-02-04T03:08:12.387Z CNTRLR   [Node 063] healing node...
2022-02-04T03:08:12.388Z CNTRLR » [Node 063] refreshing neighbor list (attempt 1)...
2022-02-04T03:08:12.404Z SERIAL » 0x010500483f67ea                                                     (7 bytes)
2022-02-04T03:08:12.406Z DRIVER » [Node 063] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 103
2022-02-04T03:08:12.409Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:12.498Z SERIAL « 0x010500486721f4                                                     (7 bytes)
2022-02-04T03:08:12.500Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:12.502Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   103
2022-02-04T03:08:15.637Z SERIAL « 0x010500486722f7                                                     (7 bytes)
2022-02-04T03:08:15.639Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:15.642Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   103
2022-02-04T03:08:15.649Z CNTRLR « [Node 063] neighbor list refreshed...
2022-02-04T03:08:15.650Z CNTRLR » [Node 063] Deleting SUC return route...
2022-02-04T03:08:15.665Z SERIAL » 0x010500553f68f8                                                     (7 bytes)
2022-02-04T03:08:15.667Z DRIVER » [Node 063] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x3f68
2022-02-04T03:08:15.671Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:15.676Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:08:15.678Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:15.680Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:15.767Z SERIAL « 0x010500556800c7                                                     (7 bytes)
2022-02-04T03:08:15.769Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:15.772Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     104
                                    transmit status: OK
2022-02-04T03:08:15.781Z CNTRLR » [Node 063] Assigning SUC return route...
2022-02-04T03:08:15.793Z SERIAL » 0x010500513f69fd                                                     (7 bytes)
2022-02-04T03:08:15.794Z DRIVER » [Node 063] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x3f69
2022-02-04T03:08:15.799Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:15.805Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:08:15.807Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:15.809Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:17.120Z SERIAL « 0x010500516900c2                                                     (7 bytes)
2022-02-04T03:08:17.122Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:17.125Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     105
                                    transmit status: OK
2022-02-04T03:08:17.135Z CNTRLR » [Node 063] deleting return routes (attempt 1)...
2022-02-04T03:08:17.146Z SERIAL » 0x010500473f6ae8                                                     (7 bytes)
2022-02-04T03:08:17.148Z DRIVER » [Node 063] [REQ] [DeleteReturnRoute]
                                    payload: 0x3f6a
2022-02-04T03:08:17.152Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:17.157Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:08:17.159Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:17.162Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:08:17.224Z SERIAL « 0x010500476a00d7                                                     (7 bytes)
2022-02-04T03:08:17.226Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:17.229Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     106
                                    transmit status: OK
2022-02-04T03:08:17.243Z CNTRLR » [Node 063] assigning return routes to the following nodes:
                                  1
2022-02-04T03:08:17.246Z CNTRLR » [Node 063] assigning return route to node 1 (attempt 1)...
2022-02-04T03:08:17.259Z SERIAL » 0x010600463f016bea                                                   (8 bytes)
2022-02-04T03:08:17.262Z DRIVER » [Node 063] [REQ] [AssignReturnRoute]
                                    payload: 0x3f016b
2022-02-04T03:08:17.267Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:17.273Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:08:17.274Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:17.278Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:08:18.521Z SERIAL « 0x010500466b00d7                                                     (7 bytes)
2022-02-04T03:08:18.523Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:18.525Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     107
                                    transmit status: OK
2022-02-04T03:08:18.535Z CNTRLR   [Node 063] healed successfully
2022-02-04T03:08:18.537Z CNTRLR » [Node 063] requesting node neighbors...
2022-02-04T03:08:18.553Z SERIAL » 0x010700803f00000047                                                 (9 bytes)
2022-02-04T03:08:18.556Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:08:18.561Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:18.566Z SERIAL « 0x0120018001020000000000a19100e801000000000000000000000000000000000 (34 bytes)
                                  084
2022-02-04T03:08:18.569Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:18.572Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 1, 10, 57, 62, 64, 65, 69, 72, 84, 86, 87, 88, 89
2022-02-04T03:08:18.580Z CNTRLR « [Node 063] node neighbors received: 1, 10, 57, 62, 64, 65, 69, 72, 84, 86, 87,
                                   88, 89
2022-02-04T03:08:18.583Z CNTRLR   [Node 010] added to healing queue for listening nodes
2022-02-04T03:08:18.586Z CNTRLR   [Node 057] added to healing queue for listening nodes
2022-02-04T03:08:18.588Z CNTRLR   [Node 062] added to healing queue for listening nodes
2022-02-04T03:08:18.591Z CNTRLR   [Node 064] added to healing queue for listening nodes
2022-02-04T03:08:18.593Z CNTRLR   [Node 065] added to healing queue for listening nodes
2022-02-04T03:08:18.594Z CNTRLR   [Node 069] added to healing queue for listening nodes
2022-02-04T03:08:18.596Z CNTRLR   [Node 084] added to healing queue for listening nodes
2022-02-04T03:08:18.597Z CNTRLR   [Node 088] added to healing queue for listening nodes
2022-02-04T03:08:18.599Z CNTRLR   [Node 089] added to healing queue for listening nodes
2022-02-04T03:08:18.600Z CNTRLR   [Node 072] healing node...
2022-02-04T03:08:18.603Z CNTRLR » [Node 072] refreshing neighbor list (attempt 1)...
2022-02-04T03:08:18.618Z SERIAL » 0x01050048486c96                                                     (7 bytes)
2022-02-04T03:08:18.620Z DRIVER » [Node 072] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 108
2022-02-04T03:08:18.624Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:18.713Z SERIAL « 0x010500486c21ff                                                     (7 bytes)
2022-02-04T03:08:18.715Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:18.717Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   108
2022-02-04T03:08:21.311Z SERIAL « 0x010500486c22fc                                                     (7 bytes)
2022-02-04T03:08:21.314Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:21.318Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   108
2022-02-04T03:08:21.330Z CNTRLR « [Node 072] neighbor list refreshed...
2022-02-04T03:08:21.331Z CNTRLR » [Node 072] Deleting SUC return route...
2022-02-04T03:08:21.341Z SERIAL » 0x01050055486d8a                                                     (7 bytes)
2022-02-04T03:08:21.343Z DRIVER » [Node 072] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x486d
2022-02-04T03:08:21.350Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:21.353Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:08:21.355Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:21.357Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:21.423Z SERIAL « 0x010500556d00c2                                                     (7 bytes)
2022-02-04T03:08:21.425Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:21.427Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     109
                                    transmit status: OK
2022-02-04T03:08:21.439Z CNTRLR » [Node 072] Assigning SUC return route...
2022-02-04T03:08:21.523Z SERIAL » 0x01050051486e8d                                                     (7 bytes)
2022-02-04T03:08:21.525Z DRIVER » [Node 072] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x486e
2022-02-04T03:08:21.532Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:21.541Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:08:21.543Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:21.546Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:22.723Z SERIAL « 0x010500516e00c5                                                     (7 bytes)
2022-02-04T03:08:22.725Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:22.727Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     110
                                    transmit status: OK
2022-02-04T03:08:22.738Z CNTRLR » [Node 072] deleting return routes (attempt 1)...
2022-02-04T03:08:22.762Z SERIAL » 0x01050047486f9a                                                     (7 bytes)
2022-02-04T03:08:22.764Z DRIVER » [Node 072] [REQ] [DeleteReturnRoute]
                                    payload: 0x486f
2022-02-04T03:08:22.769Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:22.773Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:08:22.776Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:22.779Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:08:23.271Z SERIAL « 0x010500476f00d2                                                     (7 bytes)
2022-02-04T03:08:23.273Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:23.275Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     111
                                    transmit status: OK
2022-02-04T03:08:23.291Z CNTRLR » [Node 072] assigning return routes to the following nodes:
                                  1
2022-02-04T03:08:23.292Z CNTRLR » [Node 072] assigning return route to node 1 (attempt 1)...
2022-02-04T03:08:23.302Z SERIAL » 0x0106004648017086                                                   (8 bytes)
2022-02-04T03:08:23.304Z DRIVER » [Node 072] [REQ] [AssignReturnRoute]
                                    payload: 0x480170
2022-02-04T03:08:23.308Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:23.315Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:08:23.316Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:23.318Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:08:24.542Z SERIAL « 0x010500467000cc                                                     (7 bytes)
2022-02-04T03:08:24.544Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:24.556Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     112
                                    transmit status: OK
2022-02-04T03:08:24.564Z CNTRLR   [Node 072] healed successfully
2022-02-04T03:08:24.566Z CNTRLR » [Node 072] requesting node neighbors...
2022-02-04T03:08:24.579Z SERIAL » 0x010700804800000030                                                 (9 bytes)
2022-02-04T03:08:24.581Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:08:24.586Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:24.590Z SERIAL « 0x0120018001020000000002e11144fa01000000000000000000000000000000000 (34 bytes)
                                  010
2022-02-04T03:08:24.592Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:24.595Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 1, 10, 50, 57, 62, 63, 64, 65, 69, 75, 79, 82, 84, 85, 86, 87, 88,
                                   89
2022-02-04T03:08:24.603Z CNTRLR « [Node 072] node neighbors received: 1, 10, 50, 57, 62, 63, 64, 65, 69, 75, 79,
                                   82, 84, 85, 86, 87, 88, 89
2022-02-04T03:08:24.605Z CNTRLR   [Node 050] added to healing queue for listening nodes
2022-02-04T03:08:24.606Z CNTRLR   [Node 079] healing node...
2022-02-04T03:08:24.607Z CNTRLR » [Node 079] refreshing neighbor list (attempt 1)...
2022-02-04T03:08:24.620Z SERIAL » 0x010500484f718c                                                     (7 bytes)
2022-02-04T03:08:24.622Z DRIVER » [Node 079] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 113
2022-02-04T03:08:24.630Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:24.715Z SERIAL « 0x010500487121e2                                                     (7 bytes)
2022-02-04T03:08:24.716Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:24.719Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   113
2022-02-04T03:08:27.671Z SERIAL « 0x010500487122e1                                                     (7 bytes)
2022-02-04T03:08:27.673Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:27.676Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   113
2022-02-04T03:08:27.683Z CNTRLR « [Node 079] neighbor list refreshed...
2022-02-04T03:08:27.684Z CNTRLR » [Node 079] Deleting SUC return route...
2022-02-04T03:08:27.696Z SERIAL » 0x010500554f7292                                                     (7 bytes)
2022-02-04T03:08:27.698Z DRIVER » [Node 079] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x4f72
2022-02-04T03:08:27.702Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:27.710Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:08:27.711Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:27.714Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:27.777Z SERIAL « 0x010500557200dd                                                     (7 bytes)
2022-02-04T03:08:27.779Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:27.782Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     114
                                    transmit status: OK
2022-02-04T03:08:27.790Z CNTRLR » [Node 079] Assigning SUC return route...
2022-02-04T03:08:27.801Z SERIAL » 0x010500514f7397                                                     (7 bytes)
2022-02-04T03:08:27.803Z DRIVER » [Node 079] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x4f73
2022-02-04T03:08:27.811Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:27.814Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:08:27.816Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:27.819Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:29.369Z SERIAL « 0x010500517300d8                                                     (7 bytes)
2022-02-04T03:08:29.371Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:29.373Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     115
                                    transmit status: OK
2022-02-04T03:08:29.382Z CNTRLR » [Node 079] deleting return routes (attempt 1)...
2022-02-04T03:08:29.393Z SERIAL » 0x010500474f7486                                                     (7 bytes)
2022-02-04T03:08:29.395Z DRIVER » [Node 079] [REQ] [DeleteReturnRoute]
                                    payload: 0x4f74
2022-02-04T03:08:29.399Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:29.404Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:08:29.406Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:29.408Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:08:29.471Z SERIAL « 0x010500477400c9                                                     (7 bytes)
2022-02-04T03:08:29.472Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:29.475Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     116
                                    transmit status: OK
2022-02-04T03:08:29.483Z CNTRLR » [Node 079] assigning return routes to the following nodes:
                                  1
2022-02-04T03:08:29.484Z CNTRLR » [Node 079] assigning return route to node 1 (attempt 1)...
2022-02-04T03:08:29.495Z SERIAL » 0x010600464f017584                                                   (8 bytes)
2022-02-04T03:08:29.497Z DRIVER » [Node 079] [REQ] [AssignReturnRoute]
                                    payload: 0x4f0175
2022-02-04T03:08:29.501Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:29.507Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:08:29.509Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:29.511Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:08:30.850Z SERIAL « 0x010500467500c9                                                     (7 bytes)
2022-02-04T03:08:30.851Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:30.854Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     117
                                    transmit status: OK
2022-02-04T03:08:30.883Z CNTRLR   [Node 079] healed successfully
2022-02-04T03:08:30.885Z CNTRLR » [Node 079] requesting node neighbors...
2022-02-04T03:08:30.910Z SERIAL » 0x010700804f00000037                                                 (9 bytes)
2022-02-04T03:08:30.911Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:08:30.915Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:30.919Z SERIAL « 0x01200180010000000000003081047a01000000000000000000000000000000000 (34 bytes)
                                  091
2022-02-04T03:08:30.926Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:30.928Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 1, 61, 62, 65, 72, 75, 82, 84, 85, 86, 87, 89
2022-02-04T03:08:30.937Z CNTRLR « [Node 079] node neighbors received: 1, 61, 62, 65, 72, 75, 82, 84, 85, 86, 87,
                                   89
2022-02-04T03:08:30.940Z CNTRLR   [Node 082] healing node...
2022-02-04T03:08:30.941Z CNTRLR » [Node 082] refreshing neighbor list (attempt 1)...
2022-02-04T03:08:30.954Z SERIAL » 0x01050048527696                                                     (7 bytes)
2022-02-04T03:08:30.956Z DRIVER » [Node 082] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 118
2022-02-04T03:08:30.960Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:31.051Z SERIAL « 0x010500487621e5                                                     (7 bytes)
2022-02-04T03:08:31.052Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:31.056Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   118
2022-02-04T03:08:34.716Z SERIAL « 0x010500487622e6                                                     (7 bytes)
2022-02-04T03:08:34.718Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:34.721Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   118
2022-02-04T03:08:34.728Z CNTRLR « [Node 082] neighbor list refreshed...
2022-02-04T03:08:34.729Z CNTRLR » [Node 082] Deleting SUC return route...
2022-02-04T03:08:34.745Z SERIAL » 0x0105005552778a                                                     (7 bytes)
2022-02-04T03:08:34.747Z DRIVER » [Node 082] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x5277
2022-02-04T03:08:34.752Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:34.812Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:08:34.814Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:34.817Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:35.215Z SERIAL « 0x010500557700d8                                                     (7 bytes)
2022-02-04T03:08:35.217Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:35.220Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     119
                                    transmit status: OK
2022-02-04T03:08:35.229Z CNTRLR » [Node 082] Assigning SUC return route...
2022-02-04T03:08:35.242Z SERIAL » 0x01050051527881                                                     (7 bytes)
2022-02-04T03:08:35.245Z DRIVER » [Node 082] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x5278
2022-02-04T03:08:35.249Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:35.340Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:08:35.342Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:35.344Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:36.654Z SERIAL « 0x010500517800d3                                                     (7 bytes)
2022-02-04T03:08:36.657Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:36.660Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     120
                                    transmit status: OK
2022-02-04T03:08:36.671Z CNTRLR » [Node 082] deleting return routes (attempt 1)...
2022-02-04T03:08:36.680Z SERIAL » 0x01050047527996                                                     (7 bytes)
2022-02-04T03:08:36.681Z DRIVER » [Node 082] [REQ] [DeleteReturnRoute]
                                    payload: 0x5279
2022-02-04T03:08:36.688Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:36.692Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:08:36.694Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:36.696Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:08:37.104Z SERIAL « 0x010500477900c4                                                     (7 bytes)
2022-02-04T03:08:37.106Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:37.108Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     121
                                    transmit status: OK
2022-02-04T03:08:37.120Z CNTRLR » [Node 082] assigning return routes to the following nodes:
                                  1
2022-02-04T03:08:37.124Z CNTRLR » [Node 082] assigning return route to node 1 (attempt 1)...
2022-02-04T03:08:37.136Z SERIAL » 0x0106004652017a96                                                   (8 bytes)
2022-02-04T03:08:37.137Z DRIVER » [Node 082] [REQ] [AssignReturnRoute]
                                    payload: 0x52017a
2022-02-04T03:08:37.141Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:37.231Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:08:37.233Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:37.236Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:08:38.178Z SERIAL « 0x010500467a00c6                                                     (7 bytes)
2022-02-04T03:08:38.180Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:38.182Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     122
                                    transmit status: OK
2022-02-04T03:08:38.190Z CNTRLR   [Node 082] healed successfully
2022-02-04T03:08:38.192Z CNTRLR » [Node 082] requesting node neighbors...
2022-02-04T03:08:38.202Z SERIAL » 0x01070080520000002a                                                 (9 bytes)
2022-02-04T03:08:38.203Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:08:38.208Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:38.212Z SERIAL « 0x01200180000000000000000080403000000000000000000000000000000000000 (34 bytes)
                                  0ae
2022-02-04T03:08:38.215Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:38.217Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 72, 79, 85, 86
2022-02-04T03:08:38.227Z CNTRLR « [Node 082] node neighbors received: 72, 79, 85, 86
2022-02-04T03:08:38.228Z CNTRLR   [Node 087] healing node...
2022-02-04T03:08:38.230Z CNTRLR » [Node 087] refreshing neighbor list (attempt 1)...
2022-02-04T03:08:38.246Z SERIAL » 0x01050048577b9e                                                     (7 bytes)
2022-02-04T03:08:38.248Z DRIVER » [Node 087] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 123
2022-02-04T03:08:38.253Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:38.342Z SERIAL « 0x010500487b21e8                                                     (7 bytes)
2022-02-04T03:08:38.344Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:38.347Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   123
2022-02-04T03:08:42.428Z SERIAL « 0x010500487b22eb                                                     (7 bytes)
2022-02-04T03:08:42.430Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:42.432Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   123
2022-02-04T03:08:42.439Z CNTRLR « [Node 087] neighbor list refreshed...
2022-02-04T03:08:42.440Z CNTRLR » [Node 087] Deleting SUC return route...
2022-02-04T03:08:42.453Z SERIAL » 0x01050055577c84                                                     (7 bytes)
2022-02-04T03:08:42.455Z DRIVER » [Node 087] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x577c
2022-02-04T03:08:42.460Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:42.513Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:08:42.515Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:42.517Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:42.829Z SERIAL « 0x010500557c00d3                                                     (7 bytes)
2022-02-04T03:08:42.831Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:42.834Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     124
                                    transmit status: OK
2022-02-04T03:08:42.842Z CNTRLR » [Node 087] Assigning SUC return route...
2022-02-04T03:08:42.856Z SERIAL » 0x01050051577d81                                                     (7 bytes)
2022-02-04T03:08:42.858Z DRIVER » [Node 087] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x577d
2022-02-04T03:08:42.862Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:43.195Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:08:43.197Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:43.198Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:44.190Z SERIAL « 0x010500517d00d6                                                     (7 bytes)
2022-02-04T03:08:44.192Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:44.195Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     125
                                    transmit status: OK
2022-02-04T03:08:44.205Z CNTRLR » [Node 087] deleting return routes (attempt 1)...
2022-02-04T03:08:44.217Z SERIAL » 0x01050047577e94                                                     (7 bytes)
2022-02-04T03:08:44.218Z DRIVER » [Node 087] [REQ] [DeleteReturnRoute]
                                    payload: 0x577e
2022-02-04T03:08:44.222Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:44.227Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:08:44.229Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:44.231Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:08:46.047Z SERIAL « 0x010500477e00c3                                                     (7 bytes)
2022-02-04T03:08:46.049Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:46.051Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     126
                                    transmit status: OK
2022-02-04T03:08:46.060Z CNTRLR » [Node 087] assigning return routes to the following nodes:
                                  1
2022-02-04T03:08:46.061Z CNTRLR » [Node 087] assigning return route to node 1 (attempt 1)...
2022-02-04T03:08:46.071Z SERIAL » 0x0106004657017f96                                                   (8 bytes)
2022-02-04T03:08:46.073Z DRIVER » [Node 087] [REQ] [AssignReturnRoute]
                                    payload: 0x57017f
2022-02-04T03:08:46.077Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:46.418Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:08:46.422Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:46.427Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:08:48.598Z SERIAL « 0x010500467f00c3                                                     (7 bytes)
2022-02-04T03:08:48.600Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:48.602Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     127
                                    transmit status: OK
2022-02-04T03:08:48.618Z CNTRLR   [Node 087] healed successfully
2022-02-04T03:08:48.620Z CNTRLR » [Node 087] requesting node neighbors...
2022-02-04T03:08:48.639Z SERIAL » 0x01070080570000002f                                                 (9 bytes)
2022-02-04T03:08:48.641Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:08:48.646Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:48.650Z SERIAL « 0x0120018000000000000000e181443800000000000000000000000000000000000 (34 bytes)
                                  042
2022-02-04T03:08:48.652Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:48.654Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 57, 62, 63, 64, 65, 72, 75, 79, 84, 85, 86
2022-02-04T03:08:48.662Z CNTRLR « [Node 087] node neighbors received: 57, 62, 63, 64, 65, 72, 75, 79, 84, 85, 86
2022-02-04T03:08:48.663Z CNTRLR   [Node 075] healing node...
2022-02-04T03:08:48.664Z CNTRLR » [Node 075] refreshing neighbor list (attempt 1)...
2022-02-04T03:08:48.690Z SERIAL » 0x010500484b8079                                                     (7 bytes)
2022-02-04T03:08:48.692Z DRIVER » [Node 075] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 128
2022-02-04T03:08:48.697Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:48.786Z SERIAL « 0x01050048802113                                                     (7 bytes)
2022-02-04T03:08:48.788Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:48.792Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   128
2022-02-04T03:08:53.819Z SERIAL « 0x01050048802210                                                     (7 bytes)
2022-02-04T03:08:53.822Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:53.825Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   128
2022-02-04T03:08:53.832Z CNTRLR « [Node 075] neighbor list refreshed...
2022-02-04T03:08:53.834Z CNTRLR » [Node 075] Deleting SUC return route...
2022-02-04T03:08:53.846Z SERIAL » 0x010500554b8165                                                     (7 bytes)
2022-02-04T03:08:53.848Z DRIVER » [Node 075] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x4b81
2022-02-04T03:08:53.852Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:53.905Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:08:53.907Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:53.910Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:54.135Z SERIAL « 0x0105005581002e                                                     (7 bytes)
2022-02-04T03:08:54.137Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:54.140Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     129
                                    transmit status: OK
2022-02-04T03:08:54.151Z CNTRLR » [Node 075] Assigning SUC return route...
2022-02-04T03:08:54.166Z SERIAL » 0x010500514b8262                                                     (7 bytes)
2022-02-04T03:08:54.168Z DRIVER » [Node 075] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x4b82
2022-02-04T03:08:54.174Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:54.362Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:08:54.364Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:54.366Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:08:55.494Z SERIAL « 0x01050051820029                                                     (7 bytes)
2022-02-04T03:08:55.496Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:55.499Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     130
                                    transmit status: OK
2022-02-04T03:08:55.506Z CNTRLR » [Node 075] deleting return routes (attempt 1)...
2022-02-04T03:08:55.519Z SERIAL » 0x010500474b8375                                                     (7 bytes)
2022-02-04T03:08:55.520Z DRIVER » [Node 075] [REQ] [DeleteReturnRoute]
                                    payload: 0x4b83
2022-02-04T03:08:55.524Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:55.530Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:08:55.532Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:55.534Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:08:57.161Z SERIAL « 0x0105004783003e                                                     (7 bytes)
2022-02-04T03:08:57.163Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:57.165Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     131
                                    transmit status: OK
2022-02-04T03:08:57.175Z CNTRLR » [Node 075] assigning return routes to the following nodes:
                                  1
2022-02-04T03:08:57.177Z CNTRLR » [Node 075] assigning return route to node 1 (attempt 1)...
2022-02-04T03:08:57.190Z SERIAL » 0x010600464b018471                                                   (8 bytes)
2022-02-04T03:08:57.192Z DRIVER » [Node 075] [REQ] [AssignReturnRoute]
                                    payload: 0x4b0184
2022-02-04T03:08:57.196Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:57.439Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:08:57.441Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:57.444Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:08:59.016Z SERIAL « 0x01050046840038                                                     (7 bytes)
2022-02-04T03:08:59.018Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:59.021Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     132
                                    transmit status: OK
2022-02-04T03:08:59.029Z CNTRLR   [Node 075] healed successfully
2022-02-04T03:08:59.031Z CNTRLR » [Node 075] requesting node neighbors...
2022-02-04T03:08:59.045Z SERIAL » 0x010700804b00000033                                                 (9 bytes)
2022-02-04T03:08:59.047Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:08:59.050Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:59.054Z SERIAL « 0x0120018000000000000002109048d801000000000000000000000000000000000 (34 bytes)
                                  04d
2022-02-04T03:08:59.056Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:59.059Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 50, 61, 69, 72, 76, 79, 84, 85, 87, 88, 89
2022-02-04T03:08:59.067Z CNTRLR « [Node 075] node neighbors received: 50, 61, 69, 72, 76, 79, 84, 85, 87, 88, 89
2022-02-04T03:08:59.068Z CNTRLR   [Node 076] healing node...
2022-02-04T03:08:59.071Z CNTRLR » [Node 076] refreshing neighbor list (attempt 1)...
2022-02-04T03:08:59.081Z SERIAL » 0x010500484c857b                                                     (7 bytes)
2022-02-04T03:08:59.083Z DRIVER » [Node 076] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 133
2022-02-04T03:08:59.087Z SERIAL « [ACK]        (0x06)
2022-02-04T03:08:59.176Z SERIAL « 0x01050048852116                                                     (7 bytes)
2022-02-04T03:08:59.178Z SERIAL » [ACK]        (0x06)
2022-02-04T03:08:59.180Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   133
2022-02-04T03:09:04.400Z SERIAL « 0x01050048852215                                                     (7 bytes)
2022-02-04T03:09:04.402Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:04.404Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   133
2022-02-04T03:09:04.410Z CNTRLR « [Node 076] neighbor list refreshed...
2022-02-04T03:09:04.411Z CNTRLR » [Node 076] Deleting SUC return route...
2022-02-04T03:09:04.428Z SERIAL » 0x010500554c8665                                                     (7 bytes)
2022-02-04T03:09:04.429Z DRIVER » [Node 076] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x4c86
2022-02-04T03:09:04.433Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:04.495Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:09:04.497Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:04.501Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:05.045Z SERIAL « 0x01050055860029                                                     (7 bytes)
2022-02-04T03:09:05.047Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:05.049Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     134
                                    transmit status: OK
2022-02-04T03:09:05.059Z CNTRLR » [Node 076] Assigning SUC return route...
2022-02-04T03:09:05.069Z SERIAL » 0x010500514c8760                                                     (7 bytes)
2022-02-04T03:09:05.071Z DRIVER » [Node 076] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x4c87
2022-02-04T03:09:05.078Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:05.320Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:09:05.322Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:05.325Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:06.795Z SERIAL « 0x0105005187002c                                                     (7 bytes)
2022-02-04T03:09:06.798Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:06.801Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     135
                                    transmit status: OK
2022-02-04T03:09:06.812Z CNTRLR » [Node 076] deleting return routes (attempt 1)...
2022-02-04T03:09:06.822Z SERIAL » 0x010500474c8879                                                     (7 bytes)
2022-02-04T03:09:06.823Z DRIVER » [Node 076] [REQ] [DeleteReturnRoute]
                                    payload: 0x4c88
2022-02-04T03:09:06.843Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:06.863Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:09:06.865Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:07.012Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:09:07.245Z SERIAL « 0x01050047880035                                                     (7 bytes)
2022-02-04T03:09:07.247Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:07.250Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     136
                                    transmit status: OK
2022-02-04T03:09:07.262Z CNTRLR » [Node 076] assigning return routes to the following nodes:
                                  1
2022-02-04T03:09:07.263Z CNTRLR » [Node 076] assigning return route to node 1 (attempt 1)...
2022-02-04T03:09:07.281Z SERIAL » 0x010600464c01897b                                                   (8 bytes)
2022-02-04T03:09:07.283Z DRIVER » [Node 076] [REQ] [AssignReturnRoute]
                                    payload: 0x4c0189
2022-02-04T03:09:07.289Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:07.865Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:09:07.868Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:07.870Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:09:09.516Z SERIAL « 0x01050046890035                                                     (7 bytes)
2022-02-04T03:09:09.520Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:09.524Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     137
                                    transmit status: OK
2022-02-04T03:09:09.535Z CNTRLR   [Node 076] healed successfully
2022-02-04T03:09:09.536Z CNTRLR » [Node 076] requesting node neighbors...
2022-02-04T03:09:09.547Z SERIAL » 0x010700804c00000034                                                 (9 bytes)
2022-02-04T03:09:09.549Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:09:09.554Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:09.559Z SERIAL « 0x01200180000000000000000000440000000000000000000000000000000000000 (34 bytes)
                                  01a
2022-02-04T03:09:09.561Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:09.563Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 75, 79
2022-02-04T03:09:09.569Z CNTRLR « [Node 076] node neighbors received: 75, 79
2022-02-04T03:09:09.571Z CNTRLR   [Node 085] healing node...
2022-02-04T03:09:09.572Z CNTRLR » [Node 085] refreshing neighbor list (attempt 1)...
2022-02-04T03:09:09.583Z SERIAL » 0x01050048558a6d                                                     (7 bytes)
2022-02-04T03:09:09.585Z DRIVER » [Node 085] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 138
2022-02-04T03:09:09.589Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:09.678Z SERIAL « 0x010500488a2119                                                     (7 bytes)
2022-02-04T03:09:09.680Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:09.682Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   138
2022-02-04T03:09:13.909Z SERIAL « 0x010500488a221a                                                     (7 bytes)
2022-02-04T03:09:13.911Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:13.913Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   138
2022-02-04T03:09:13.922Z CNTRLR « [Node 085] neighbor list refreshed...
2022-02-04T03:09:13.923Z CNTRLR » [Node 085] Deleting SUC return route...
2022-02-04T03:09:13.934Z SERIAL » 0x01050055558b71                                                     (7 bytes)
2022-02-04T03:09:13.936Z DRIVER » [Node 085] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x558b
2022-02-04T03:09:13.940Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:13.993Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:09:13.995Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:13.997Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:14.292Z SERIAL « 0x010500558b0024                                                     (7 bytes)
2022-02-04T03:09:14.294Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:14.296Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     139
                                    transmit status: OK
2022-02-04T03:09:14.306Z CNTRLR » [Node 085] Assigning SUC return route...
2022-02-04T03:09:14.319Z SERIAL » 0x01050051558c72                                                     (7 bytes)
2022-02-04T03:09:14.321Z DRIVER » [Node 085] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x558c
2022-02-04T03:09:14.325Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:14.663Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:09:14.666Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:14.668Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:15.756Z SERIAL « 0x010500518c0027                                                     (7 bytes)
2022-02-04T03:09:15.758Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:15.763Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     140
                                    transmit status: OK
2022-02-04T03:09:15.773Z CNTRLR » [Node 085] deleting return routes (attempt 1)...
2022-02-04T03:09:15.788Z SERIAL » 0x01050047558d65                                                     (7 bytes)
2022-02-04T03:09:15.789Z DRIVER » [Node 085] [REQ] [DeleteReturnRoute]
                                    payload: 0x558d
2022-02-04T03:09:15.795Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:15.800Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:09:15.802Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:15.805Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:09:16.683Z SERIAL « 0x010500478d0030                                                     (7 bytes)
2022-02-04T03:09:16.686Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:16.689Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     141
                                    transmit status: OK
2022-02-04T03:09:16.700Z CNTRLR » [Node 085] assigning return routes to the following nodes:
                                  1
2022-02-04T03:09:16.702Z CNTRLR » [Node 085] assigning return route to node 1 (attempt 1)...
2022-02-04T03:09:16.714Z SERIAL » 0x0106004655018e65                                                   (8 bytes)
2022-02-04T03:09:16.716Z DRIVER » [Node 085] [REQ] [AssignReturnRoute]
                                    payload: 0x55018e
2022-02-04T03:09:16.723Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:17.060Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:09:17.062Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:17.065Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:09:18.082Z SERIAL « 0x010500468e0032                                                     (7 bytes)
2022-02-04T03:09:18.084Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:18.087Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     142
                                    transmit status: OK
2022-02-04T03:09:18.095Z CNTRLR   [Node 085] healed successfully
2022-02-04T03:09:18.096Z CNTRLR » [Node 085] requesting node neighbors...
2022-02-04T03:09:18.108Z SERIAL » 0x01070080550000002d                                                 (9 bytes)
2022-02-04T03:09:18.110Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:09:18.113Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:18.117Z SERIAL « 0x01200180000000000000021080446200000000000000000000000000000000000 (34 bytes)
                                  0ea
2022-02-04T03:09:18.119Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:18.121Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 50, 61, 72, 75, 79, 82, 86, 87
2022-02-04T03:09:18.131Z CNTRLR « [Node 085] node neighbors received: 50, 61, 72, 75, 79, 82, 86, 87
2022-02-04T03:09:18.132Z CNTRLR   [Node 086] healing node...
2022-02-04T03:09:18.133Z CNTRLR » [Node 086] refreshing neighbor list (attempt 1)...
2022-02-04T03:09:18.144Z SERIAL » 0x01050048568f6b                                                     (7 bytes)
2022-02-04T03:09:18.145Z DRIVER » [Node 086] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 143
2022-02-04T03:09:18.149Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:18.239Z SERIAL « 0x010500488f211c                                                     (7 bytes)
2022-02-04T03:09:18.241Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:18.245Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   143
2022-02-04T03:09:21.613Z SERIAL « 0x010500488f221f                                                     (7 bytes)
2022-02-04T03:09:21.615Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:21.617Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   143
2022-02-04T03:09:21.624Z CNTRLR « [Node 086] neighbor list refreshed...
2022-02-04T03:09:21.625Z CNTRLR » [Node 086] Deleting SUC return route...
2022-02-04T03:09:21.638Z SERIAL » 0x01050055569069                                                     (7 bytes)
2022-02-04T03:09:21.639Z DRIVER » [Node 086] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x5690
2022-02-04T03:09:21.643Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:21.647Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:09:21.649Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:21.651Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:21.851Z SERIAL « 0x0105005590003f                                                     (7 bytes)
2022-02-04T03:09:21.853Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:21.855Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     144
                                    transmit status: OK
2022-02-04T03:09:21.863Z CNTRLR » [Node 086] Assigning SUC return route...
2022-02-04T03:09:21.877Z SERIAL » 0x0105005156916c                                                     (7 bytes)
2022-02-04T03:09:21.878Z DRIVER » [Node 086] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x5691
2022-02-04T03:09:21.882Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:21.889Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:09:21.890Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:21.892Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:23.374Z SERIAL « 0x0105005191003a                                                     (7 bytes)
2022-02-04T03:09:23.377Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:23.380Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     145
                                    transmit status: OK
2022-02-04T03:09:23.389Z CNTRLR » [Node 086] deleting return routes (attempt 1)...
2022-02-04T03:09:23.399Z SERIAL » 0x01050047569279                                                     (7 bytes)
2022-02-04T03:09:23.401Z DRIVER » [Node 086] [REQ] [DeleteReturnRoute]
                                    payload: 0x5692
2022-02-04T03:09:23.404Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:23.410Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:09:23.411Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:23.414Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:09:23.759Z SERIAL « 0x0105004792002f                                                     (7 bytes)
2022-02-04T03:09:23.761Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:23.763Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     146
                                    transmit status: OK
2022-02-04T03:09:23.771Z CNTRLR » [Node 086] assigning return routes to the following nodes:
                                  1
2022-02-04T03:09:23.772Z CNTRLR » [Node 086] assigning return route to node 1 (attempt 1)...
2022-02-04T03:09:23.782Z SERIAL » 0x010600465601937b                                                   (8 bytes)
2022-02-04T03:09:23.783Z DRIVER » [Node 086] [REQ] [AssignReturnRoute]
                                    payload: 0x560193
2022-02-04T03:09:23.786Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:23.793Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:09:23.794Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:23.797Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:09:25.085Z SERIAL « 0x0105004693002f                                                     (7 bytes)
2022-02-04T03:09:25.087Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:25.089Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     147
                                    transmit status: OK
2022-02-04T03:09:25.096Z CNTRLR   [Node 086] healed successfully
2022-02-04T03:09:25.097Z CNTRLR » [Node 086] requesting node neighbors...
2022-02-04T03:09:25.107Z SERIAL » 0x01070080560000002e                                                 (9 bytes)
2022-02-04T03:09:25.109Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:09:25.112Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:25.116Z SERIAL « 0x012001800100000000000a508040da01000000000000000000000000000000000 (34 bytes)
                                  01e
2022-02-04T03:09:25.118Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:25.119Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 1, 50, 52, 61, 63, 72, 79, 82, 84, 85, 87, 88, 89
2022-02-04T03:09:25.126Z CNTRLR « [Node 086] node neighbors received: 1, 50, 52, 61, 63, 72, 79, 82, 84, 85, 87,
                                   88, 89
2022-02-04T03:09:25.130Z CNTRLR   [Node 052] added to healing queue for listening nodes
2022-02-04T03:09:25.131Z CNTRLR   [Node 010] healing node...
2022-02-04T03:09:25.132Z CNTRLR » [Node 010] refreshing neighbor list (attempt 1)...
2022-02-04T03:09:25.144Z SERIAL » 0x010500480a942c                                                     (7 bytes)
2022-02-04T03:09:25.146Z DRIVER » [Node 010] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 148
2022-02-04T03:09:25.149Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:25.239Z SERIAL « 0x01050048942107                                                     (7 bytes)
2022-02-04T03:09:25.240Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:25.242Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   148
2022-02-04T03:09:27.927Z SERIAL « 0x01060004000a00f7                                                   (8 bytes)
2022-02-04T03:09:27.932Z DRIVER   Dropping message with invalid payload:
                                  0x01060004000a00f7
2022-02-04T03:09:27.934Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:31.023Z SERIAL « 0x01050048942204                                                     (7 bytes)
2022-02-04T03:09:31.024Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:31.026Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   148
2022-02-04T03:09:31.031Z CNTRLR « [Node 010] neighbor list refreshed...
2022-02-04T03:09:31.037Z CNTRLR » [Node 010] Deleting SUC return route...
2022-02-04T03:09:31.050Z SERIAL » 0x010500550a9530                                                     (7 bytes)
2022-02-04T03:09:31.053Z DRIVER » [Node 010] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x0a95
2022-02-04T03:09:31.059Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:31.692Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:09:31.694Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:31.696Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:32.043Z SERIAL « 0x0105005595003a                                                     (7 bytes)
2022-02-04T03:09:32.046Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:32.048Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     149
                                    transmit status: OK
2022-02-04T03:09:32.056Z CNTRLR » [Node 010] Assigning SUC return route...
2022-02-04T03:09:32.068Z SERIAL » 0x010500510a9637                                                     (7 bytes)
2022-02-04T03:09:32.073Z DRIVER » [Node 010] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x0a96
2022-02-04T03:09:32.078Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:32.270Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:09:32.272Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:32.275Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:33.265Z SERIAL « 0x0105005196003d                                                     (7 bytes)
2022-02-04T03:09:33.267Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:33.270Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     150
                                    transmit status: OK
2022-02-04T03:09:33.286Z CNTRLR » [Node 010] deleting return routes (attempt 1)...
2022-02-04T03:09:33.328Z SERIAL » 0x010500470a9720                                                     (7 bytes)
2022-02-04T03:09:33.330Z DRIVER » [Node 010] [REQ] [DeleteReturnRoute]
                                    payload: 0x0a97
2022-02-04T03:09:33.335Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:33.342Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:09:33.344Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:33.346Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:09:34.655Z SERIAL « 0x0105004797002a                                                     (7 bytes)
2022-02-04T03:09:34.657Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:34.659Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     151
                                    transmit status: OK
2022-02-04T03:09:34.667Z CNTRLR » [Node 010] assigning return routes to the following nodes:
                                  1, 3, 5
2022-02-04T03:09:34.669Z CNTRLR » [Node 010] assigning return route to node 1 (attempt 1)...
2022-02-04T03:09:34.683Z SERIAL » 0x010600460a01982c                                                   (8 bytes)
2022-02-04T03:09:34.684Z DRIVER » [Node 010] [REQ] [AssignReturnRoute]
                                    payload: 0x0a0198
2022-02-04T03:09:34.688Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:35.028Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:09:35.029Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:35.031Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:09:35.831Z SERIAL « 0x01050046980024                                                     (7 bytes)
2022-02-04T03:09:35.833Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:35.838Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     152
                                    transmit status: OK
2022-02-04T03:09:35.845Z CNTRLR » [Node 010] assigning return route to node 3 (attempt 1)...
2022-02-04T03:09:35.858Z SERIAL » 0x010600460a03992f                                                   (8 bytes)
2022-02-04T03:09:35.860Z DRIVER » [Node 010] [REQ] [AssignReturnRoute]
                                    payload: 0x0a0399
2022-02-04T03:09:35.863Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:35.870Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:09:35.871Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:35.873Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:09:36.375Z SERIAL « 0x01050046990025                                                     (7 bytes)
2022-02-04T03:09:36.377Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:36.379Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     153
                                    transmit status: OK
2022-02-04T03:09:36.389Z CNTRLR » [Node 010] assigning return route to node 5 (attempt 1)...
2022-02-04T03:09:36.404Z SERIAL » 0x010600460a059a2a                                                   (8 bytes)
2022-02-04T03:09:36.406Z DRIVER » [Node 010] [REQ] [AssignReturnRoute]
                                    payload: 0x0a059a
2022-02-04T03:09:36.413Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:36.417Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:09:36.419Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:36.421Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:09:36.735Z SERIAL « 0x010500469a0026                                                     (7 bytes)
2022-02-04T03:09:36.740Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:36.744Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     154
                                    transmit status: OK
2022-02-04T03:09:36.753Z CNTRLR   [Node 010] healed successfully
2022-02-04T03:09:36.758Z CNTRLR » [Node 010] requesting node neighbors...
2022-02-04T03:09:36.773Z SERIAL » 0x010700800a00000072                                                 (9 bytes)
2022-02-04T03:09:36.777Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:09:36.782Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:36.785Z SERIAL « 0x0120018000000000000000e091008000000000000000000000000000000000000 (34 bytes)
                                  0af
2022-02-04T03:09:36.788Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:36.790Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 62, 63, 64, 65, 69, 72, 88
2022-02-04T03:09:36.799Z CNTRLR « [Node 010] node neighbors received: 62, 63, 64, 65, 69, 72, 88
2022-02-04T03:09:36.801Z CNTRLR   [Node 057] healing node...
2022-02-04T03:09:36.802Z CNTRLR » [Node 057] refreshing neighbor list (attempt 1)...
2022-02-04T03:09:36.815Z SERIAL » 0x01050048399b10                                                     (7 bytes)
2022-02-04T03:09:36.817Z DRIVER » [Node 057] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 155
2022-02-04T03:09:36.821Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:36.913Z SERIAL « 0x010500489b2108                                                     (7 bytes)
2022-02-04T03:09:36.915Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:36.917Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   155
2022-02-04T03:09:42.143Z SERIAL « 0x010500489b220b                                                     (7 bytes)
2022-02-04T03:09:42.145Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:42.147Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   155
2022-02-04T03:09:42.155Z CNTRLR « [Node 057] neighbor list refreshed...
2022-02-04T03:09:42.156Z CNTRLR » [Node 057] Deleting SUC return route...
2022-02-04T03:09:42.169Z SERIAL » 0x01050055399c0a                                                     (7 bytes)
2022-02-04T03:09:42.173Z DRIVER » [Node 057] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x399c
2022-02-04T03:09:42.178Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:42.232Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:09:42.235Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:42.239Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:42.546Z SERIAL « 0x010500559c0033                                                     (7 bytes)
2022-02-04T03:09:42.548Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:42.552Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     156
                                    transmit status: OK
2022-02-04T03:09:42.558Z CNTRLR » [Node 057] Assigning SUC return route...
2022-02-04T03:09:42.571Z SERIAL » 0x01050051399d0f                                                     (7 bytes)
2022-02-04T03:09:42.572Z DRIVER » [Node 057] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x399d
2022-02-04T03:09:42.576Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:42.916Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:09:42.919Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:42.921Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:43.868Z SERIAL « 0x010500519d0036                                                     (7 bytes)
2022-02-04T03:09:43.872Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:43.875Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     157
                                    transmit status: OK
2022-02-04T03:09:43.889Z CNTRLR » [Node 057] deleting return routes (attempt 1)...
2022-02-04T03:09:43.902Z SERIAL » 0x01050047399e1a                                                     (7 bytes)
2022-02-04T03:09:43.905Z DRIVER » [Node 057] [REQ] [DeleteReturnRoute]
                                    payload: 0x399e
2022-02-04T03:09:43.910Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:43.917Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:09:43.919Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:43.922Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:09:48.115Z SERIAL « 0x010500479e0023                                                     (7 bytes)
2022-02-04T03:09:48.117Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:48.119Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     158
                                    transmit status: OK
2022-02-04T03:09:48.127Z CNTRLR » [Node 057] assigning return routes to the following nodes:
                                  1
2022-02-04T03:09:48.129Z CNTRLR » [Node 057] assigning return route to node 1 (attempt 1)...
2022-02-04T03:09:48.142Z SERIAL » 0x0106004639019f18                                                   (8 bytes)
2022-02-04T03:09:48.144Z DRIVER » [Node 057] [REQ] [AssignReturnRoute]
                                    payload: 0x39019f
2022-02-04T03:09:48.148Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:48.996Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:09:48.999Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:49.004Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:09:50.700Z SERIAL « 0x010500469f0023                                                     (7 bytes)
2022-02-04T03:09:50.702Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:50.704Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     159
                                    transmit status: OK
2022-02-04T03:09:50.712Z CNTRLR   [Node 057] healed successfully
2022-02-04T03:09:50.714Z CNTRLR » [Node 057] requesting node neighbors...
2022-02-04T03:09:50.726Z SERIAL » 0x010700803900000041                                                 (9 bytes)
2022-02-04T03:09:50.728Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:09:50.732Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:50.736Z SERIAL « 0x0120018000000000000000e091804000000000000000000000000000000000000 (34 bytes)
                                  0ef
2022-02-04T03:09:50.738Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:50.740Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 62, 63, 64, 65, 69, 72, 80, 87
2022-02-04T03:09:50.750Z CNTRLR « [Node 057] node neighbors received: 62, 63, 64, 65, 69, 72, 80, 87
2022-02-04T03:09:50.751Z CNTRLR   [Node 080] added to healing queue for listening nodes
2022-02-04T03:09:50.752Z CNTRLR   [Node 062] healing node...
2022-02-04T03:09:50.753Z CNTRLR » [Node 062] refreshing neighbor list (attempt 1)...
2022-02-04T03:09:50.764Z SERIAL » 0x010500483ea02c                                                     (7 bytes)
2022-02-04T03:09:50.766Z DRIVER » [Node 062] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 160
2022-02-04T03:09:50.772Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:50.861Z SERIAL « 0x01050048a02133                                                     (7 bytes)
2022-02-04T03:09:50.862Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:50.864Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   160
2022-02-04T03:09:55.501Z SERIAL « 0x01050048a02230                                                     (7 bytes)
2022-02-04T03:09:55.502Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:55.505Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   160
2022-02-04T03:09:55.514Z CNTRLR « [Node 062] neighbor list refreshed...
2022-02-04T03:09:55.515Z CNTRLR » [Node 062] Deleting SUC return route...
2022-02-04T03:09:55.526Z SERIAL » 0x010500553ea130                                                     (7 bytes)
2022-02-04T03:09:55.527Z DRIVER » [Node 062] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x3ea1
2022-02-04T03:09:55.531Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:55.585Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:09:55.587Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:55.589Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:55.830Z SERIAL « 0x01050055a1000e                                                     (7 bytes)
2022-02-04T03:09:55.833Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:55.836Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     161
                                    transmit status: OK
2022-02-04T03:09:55.848Z CNTRLR » [Node 062] Assigning SUC return route...
2022-02-04T03:09:55.864Z SERIAL » 0x010500513ea237                                                     (7 bytes)
2022-02-04T03:09:55.865Z DRIVER » [Node 062] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x3ea2
2022-02-04T03:09:55.870Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:56.201Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:09:56.203Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:56.205Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:09:57.089Z SERIAL « 0x01050051a20009                                                     (7 bytes)
2022-02-04T03:09:57.091Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:57.093Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     162
                                    transmit status: OK
2022-02-04T03:09:57.106Z CNTRLR » [Node 062] deleting return routes (attempt 1)...
2022-02-04T03:09:57.118Z SERIAL » 0x010500473ea320                                                     (7 bytes)
2022-02-04T03:09:57.119Z DRIVER » [Node 062] [REQ] [DeleteReturnRoute]
                                    payload: 0x3ea3
2022-02-04T03:09:57.125Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:57.133Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:09:57.135Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:57.138Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:09:57.370Z SERIAL « 0x01050047a3001e                                                     (7 bytes)
2022-02-04T03:09:57.371Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:57.374Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     163
                                    transmit status: OK
2022-02-04T03:09:57.384Z CNTRLR » [Node 062] assigning return routes to the following nodes:
                                  1
2022-02-04T03:09:57.385Z CNTRLR » [Node 062] assigning return route to node 1 (attempt 1)...
2022-02-04T03:09:57.399Z SERIAL » 0x010600463e01a424                                                   (8 bytes)
2022-02-04T03:09:57.401Z DRIVER » [Node 062] [REQ] [AssignReturnRoute]
                                    payload: 0x3e01a4
2022-02-04T03:09:57.405Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:57.690Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:09:57.693Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:57.696Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:09:58.684Z SERIAL « 0x01050046a40018                                                     (7 bytes)
2022-02-04T03:09:58.686Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:58.689Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     164
                                    transmit status: OK
2022-02-04T03:09:58.700Z CNTRLR   [Node 062] healed successfully
2022-02-04T03:09:58.702Z CNTRLR » [Node 062] requesting node neighbors...
2022-02-04T03:09:58.718Z SERIAL » 0x010700803e00000046                                                 (9 bytes)
2022-02-04T03:09:58.720Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:09:58.725Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:58.730Z SERIAL « 0x0120018000020000000000c181404800000000000000000000000000000000000 (34 bytes)
                                  014
2022-02-04T03:09:58.733Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:58.736Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 10, 57, 63, 64, 65, 72, 79, 84, 87
2022-02-04T03:09:58.745Z CNTRLR « [Node 062] node neighbors received: 10, 57, 63, 64, 65, 72, 79, 84, 87
2022-02-04T03:09:58.747Z CNTRLR   [Node 064] healing node...
2022-02-04T03:09:58.749Z CNTRLR » [Node 064] refreshing neighbor list (attempt 1)...
2022-02-04T03:09:58.773Z SERIAL » 0x0105004840a557                                                     (7 bytes)
2022-02-04T03:09:58.775Z DRIVER » [Node 064] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 165
2022-02-04T03:09:58.783Z SERIAL « [ACK]        (0x06)
2022-02-04T03:09:58.869Z SERIAL « 0x01050048a52136                                                     (7 bytes)
2022-02-04T03:09:58.872Z SERIAL » [ACK]        (0x06)
2022-02-04T03:09:58.876Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   165
2022-02-04T03:10:06.688Z SERIAL « 0x01050048a52235                                                     (7 bytes)
2022-02-04T03:10:06.690Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:06.692Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   165
2022-02-04T03:10:06.699Z CNTRLR « [Node 064] neighbor list refreshed...
2022-02-04T03:10:06.701Z CNTRLR » [Node 064] Deleting SUC return route...
2022-02-04T03:10:06.713Z SERIAL » 0x0105005540a649                                                     (7 bytes)
2022-02-04T03:10:06.714Z DRIVER » [Node 064] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x40a6
2022-02-04T03:10:06.719Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:06.982Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:10:06.985Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:06.988Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:07.252Z SERIAL « 0x01050055a60009                                                     (7 bytes)
2022-02-04T03:10:07.254Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:07.257Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     166
                                    transmit status: OK
2022-02-04T03:10:07.269Z CNTRLR » [Node 064] Assigning SUC return route...
2022-02-04T03:10:07.285Z SERIAL » 0x0105005140a74c                                                     (7 bytes)
2022-02-04T03:10:07.287Z DRIVER » [Node 064] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x40a7
2022-02-04T03:10:07.291Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:07.474Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:10:07.476Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:07.479Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:08.243Z SERIAL « 0x01050051a7000c                                                     (7 bytes)
2022-02-04T03:10:08.246Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:08.249Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     167
                                    transmit status: OK
2022-02-04T03:10:08.261Z CNTRLR » [Node 064] deleting return routes (attempt 1)...
2022-02-04T03:10:08.274Z SERIAL » 0x0105004740a855                                                     (7 bytes)
2022-02-04T03:10:08.276Z DRIVER » [Node 064] [REQ] [DeleteReturnRoute]
                                    payload: 0x40a8
2022-02-04T03:10:08.280Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:08.285Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:10:08.287Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:08.292Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:10:08.535Z SERIAL « 0x01050047a80015                                                     (7 bytes)
2022-02-04T03:10:08.536Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:08.539Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     168
                                    transmit status: OK
2022-02-04T03:10:08.548Z CNTRLR » [Node 064] assigning return routes to the following nodes:
                                  1
2022-02-04T03:10:08.550Z CNTRLR » [Node 064] assigning return route to node 1 (attempt 1)...
2022-02-04T03:10:08.563Z SERIAL » 0x010600464001a957                                                   (8 bytes)
2022-02-04T03:10:08.565Z DRIVER » [Node 064] [REQ] [AssignReturnRoute]
                                    payload: 0x4001a9
2022-02-04T03:10:08.569Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:08.900Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:10:08.903Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:08.905Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:10:09.669Z SERIAL « 0x01050046a90015                                                     (7 bytes)
2022-02-04T03:10:09.671Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:09.673Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     169
                                    transmit status: OK
2022-02-04T03:10:09.683Z CNTRLR   [Node 064] healed successfully
2022-02-04T03:10:09.685Z CNTRLR » [Node 064] requesting node neighbors...
2022-02-04T03:10:09.698Z SERIAL » 0x010700804000000038                                                 (9 bytes)
2022-02-04T03:10:09.700Z DRIVER » [REQ] [GetRoutingInfo]
                                    remove non-repeaters: false
                                    remove bad links:     false
2022-02-04T03:10:09.704Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:09.708Z SERIAL « 0x0120018000020000000000619180c000000000000000000000000000000000000 (34 bytes)
                                  0ec
2022-02-04T03:10:09.710Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:09.712Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 10, 57, 62, 63, 65, 69, 72, 80, 87, 88
2022-02-04T03:10:09.721Z CNTRLR « [Node 064] node neighbors received: 10, 57, 62, 63, 65, 69, 72, 80, 87, 88
2022-02-04T03:10:09.723Z CNTRLR   [Node 065] healing node...
2022-02-04T03:10:09.727Z CNTRLR » [Node 065] refreshing neighbor list (attempt 1)...
2022-02-04T03:10:09.738Z SERIAL » 0x0105004841aa59                                                     (7 bytes)
2022-02-04T03:10:09.740Z DRIVER » [Node 065] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 170
2022-02-04T03:10:09.744Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:09.833Z SERIAL « 0x01050048aa2139                                                     (7 bytes)
2022-02-04T03:10:09.834Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:09.837Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   170
                                    update status: UpdateStarted
2022-02-04T03:10:13.093Z SERIAL « 0x01050048aa223a                                                     (7 bytes)
2022-02-04T03:10:13.095Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:13.099Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   170
                                    update status: UpdateDone
2022-02-04T03:10:13.108Z CNTRLR « [Node 065] neighbor list refreshed...
2022-02-04T03:10:13.109Z CNTRLR » [Node 065] Deleting SUC return route...
2022-02-04T03:10:13.121Z SERIAL » 0x0105005541ab45                                                     (7 bytes)
2022-02-04T03:10:13.123Z DRIVER » [Node 065] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x41ab
2022-02-04T03:10:13.134Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:13.188Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:10:13.190Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:13.196Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:13.622Z SERIAL « 0x01050055ab0004                                                     (7 bytes)
2022-02-04T03:10:13.625Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:13.627Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     171
                                    transmit status: OK
2022-02-04T03:10:13.639Z CNTRLR » [Node 065] Assigning SUC return route...
2022-02-04T03:10:13.651Z SERIAL » 0x0105005141ac46                                                     (7 bytes)
2022-02-04T03:10:13.653Z DRIVER » [Node 065] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x41ac
2022-02-04T03:10:13.657Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:13.987Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:10:13.989Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:13.992Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:14.983Z SERIAL « 0x01050051ac0007                                                     (7 bytes)
2022-02-04T03:10:14.985Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:14.987Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     172
                                    transmit status: OK
2022-02-04T03:10:15.017Z CNTRLR » [Node 065] deleting return routes (attempt 1)...
2022-02-04T03:10:15.030Z SERIAL » 0x0105004741ad51                                                     (7 bytes)
2022-02-04T03:10:15.031Z DRIVER » [Node 065] [REQ] [DeleteReturnRoute]
                                    payload: 0x41ad
2022-02-04T03:10:15.035Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:15.039Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:10:15.041Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:15.043Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:10:15.281Z SERIAL « 0x01050047ad0010                                                     (7 bytes)
2022-02-04T03:10:15.283Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:15.286Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     173
                                    transmit status: OK
2022-02-04T03:10:15.294Z CNTRLR » [Node 065] assigning return routes to the following nodes:
                                  1
2022-02-04T03:10:15.295Z CNTRLR » [Node 065] assigning return route to node 1 (attempt 1)...
2022-02-04T03:10:15.308Z SERIAL » 0x010600464101ae51                                                   (8 bytes)
2022-02-04T03:10:15.309Z DRIVER » [Node 065] [REQ] [AssignReturnRoute]
                                    payload: 0x4101ae
2022-02-04T03:10:15.314Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:15.646Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:10:15.648Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:15.652Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:10:16.641Z SERIAL « 0x01050046ae0012                                                     (7 bytes)
2022-02-04T03:10:16.643Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:16.647Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     174
                                    transmit status: OK
2022-02-04T03:10:16.655Z CNTRLR   [Node 065] healed successfully
2022-02-04T03:10:16.657Z CNTRLR » [Node 065] requesting node neighbors...
2022-02-04T03:10:16.667Z SERIAL » 0x010700804100000039                                                 (9 bytes)
2022-02-04T03:10:16.669Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:10:16.677Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:16.680Z SERIAL « 0x0120018000020000000008e190c0c801000000000000000000000000000000000 (34 bytes)
                                  02c
2022-02-04T03:10:16.682Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:16.684Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 10, 52, 57, 62, 63, 64, 69, 72, 79, 80, 84, 87, 88, 89
2022-02-04T03:10:16.691Z CNTRLR « [Node 065] node neighbors received: 10, 52, 57, 62, 63, 64, 69, 72, 79, 80, 84
                                  , 87, 88, 89
2022-02-04T03:10:16.692Z CNTRLR   [Node 069] healing node...
2022-02-04T03:10:16.693Z CNTRLR » [Node 069] refreshing neighbor list (attempt 1)...
2022-02-04T03:10:16.703Z SERIAL » 0x0105004845af58                                                     (7 bytes)
2022-02-04T03:10:16.705Z DRIVER » [Node 069] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 175
2022-02-04T03:10:16.709Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:16.798Z SERIAL « 0x01050048af213c                                                     (7 bytes)
2022-02-04T03:10:16.801Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:16.804Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   175
2022-02-04T03:10:21.632Z SERIAL « 0x01050048af223f                                                     (7 bytes)
2022-02-04T03:10:21.634Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:21.637Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   175
2022-02-04T03:10:21.643Z CNTRLR « [Node 069] neighbor list refreshed...
2022-02-04T03:10:21.644Z CNTRLR » [Node 069] Deleting SUC return route...
2022-02-04T03:10:21.653Z SERIAL » 0x0105005545b05a                                                     (7 bytes)
2022-02-04T03:10:21.655Z DRIVER » [Node 069] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x45b0
2022-02-04T03:10:21.658Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:21.816Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:10:21.827Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:21.834Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:22.769Z SERIAL « 0x01050055b0001f                                                     (7 bytes)
2022-02-04T03:10:22.771Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:22.773Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     176
                                    transmit status: OK
2022-02-04T03:10:22.780Z CNTRLR » [Node 069] Assigning SUC return route...
2022-02-04T03:10:22.805Z SERIAL » 0x0105005145b15f                                                     (7 bytes)
2022-02-04T03:10:22.807Z DRIVER » [Node 069] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x45b1
2022-02-04T03:10:22.814Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:23.145Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:10:23.147Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:23.150Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:24.174Z SERIAL « 0x01050051b1001a                                                     (7 bytes)
2022-02-04T03:10:24.177Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:24.181Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     177
                                    transmit status: OK
2022-02-04T03:10:24.190Z CNTRLR » [Node 069] deleting return routes (attempt 1)...
2022-02-04T03:10:24.203Z SERIAL » 0x0105004745b24a                                                     (7 bytes)
2022-02-04T03:10:24.204Z DRIVER » [Node 069] [REQ] [DeleteReturnRoute]
                                    payload: 0x45b2
2022-02-04T03:10:24.209Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:24.213Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:10:24.214Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:24.217Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:10:24.959Z SERIAL « 0x01050047b2000f                                                     (7 bytes)
2022-02-04T03:10:24.961Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:24.963Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     178
                                    transmit status: OK
2022-02-04T03:10:24.975Z CNTRLR » [Node 069] assigning return routes to the following nodes:
                                  1
2022-02-04T03:10:24.976Z CNTRLR » [Node 069] assigning return route to node 1 (attempt 1)...
2022-02-04T03:10:24.988Z SERIAL » 0x010600464501b348                                                   (8 bytes)
2022-02-04T03:10:24.990Z DRIVER » [Node 069] [REQ] [AssignReturnRoute]
                                    payload: 0x4501b3
2022-02-04T03:10:24.994Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:25.178Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:10:25.179Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:25.182Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:10:26.057Z SERIAL « 0x01050046b3000f                                                     (7 bytes)
2022-02-04T03:10:26.059Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:26.062Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     179
                                    transmit status: OK
2022-02-04T03:10:26.071Z CNTRLR   [Node 069] healed successfully
2022-02-04T03:10:26.074Z CNTRLR » [Node 069] requesting node neighbors...
2022-02-04T03:10:26.090Z SERIAL » 0x01070080450000003d                                                 (9 bytes)
2022-02-04T03:10:26.092Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:10:26.096Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:26.100Z SERIAL « 0x0120018000020000000008c181848801000000000000000000000000000000000 (34 bytes)
                                  019
2022-02-04T03:10:26.103Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:26.106Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 10, 52, 57, 63, 64, 65, 72, 75, 80, 84, 88, 89
2022-02-04T03:10:26.117Z CNTRLR « [Node 069] node neighbors received: 10, 52, 57, 63, 64, 65, 72, 75, 80, 84, 88
                                  , 89
2022-02-04T03:10:26.119Z CNTRLR   [Node 084] healing node...
2022-02-04T03:10:26.121Z CNTRLR » [Node 084] refreshing neighbor list (attempt 1)...
2022-02-04T03:10:26.132Z SERIAL » 0x0105004854b452                                                     (7 bytes)
2022-02-04T03:10:26.134Z DRIVER » [Node 084] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 180
2022-02-04T03:10:26.138Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:26.227Z SERIAL « 0x01050048b42127                                                     (7 bytes)
2022-02-04T03:10:26.229Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:26.233Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   180
2022-02-04T03:10:30.496Z SERIAL « 0x01050048b42224                                                     (7 bytes)
2022-02-04T03:10:30.500Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:30.504Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   180
2022-02-04T03:10:30.512Z CNTRLR « [Node 084] neighbor list refreshed...
2022-02-04T03:10:30.515Z CNTRLR » [Node 084] Deleting SUC return route...
2022-02-04T03:10:30.529Z SERIAL » 0x0105005554b54e                                                     (7 bytes)
2022-02-04T03:10:30.532Z DRIVER » [Node 084] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x54b5
2022-02-04T03:10:30.537Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:30.592Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:10:30.594Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:30.598Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:30.932Z SERIAL « 0x01050055b5001a                                                     (7 bytes)
2022-02-04T03:10:30.938Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:30.941Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     181
                                    transmit status: OK
2022-02-04T03:10:30.950Z CNTRLR » [Node 084] Assigning SUC return route...
2022-02-04T03:10:30.966Z SERIAL » 0x0105005154b649                                                     (7 bytes)
2022-02-04T03:10:30.968Z DRIVER » [Node 084] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x54b6
2022-02-04T03:10:30.973Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:31.259Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:10:31.261Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:31.263Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:32.582Z SERIAL « 0x01050051b6001d                                                     (7 bytes)
2022-02-04T03:10:32.584Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:32.586Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     182
                                    transmit status: OK
2022-02-04T03:10:32.597Z CNTRLR » [Node 084] deleting return routes (attempt 1)...
2022-02-04T03:10:32.606Z SERIAL » 0x0105004754b75e                                                     (7 bytes)
2022-02-04T03:10:32.608Z DRIVER » [Node 084] [REQ] [DeleteReturnRoute]
                                    payload: 0x54b7
2022-02-04T03:10:32.615Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:32.619Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:10:32.621Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:32.624Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:10:34.831Z SERIAL « 0x01050047b7000a                                                     (7 bytes)
2022-02-04T03:10:34.833Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:34.835Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     183
                                    transmit status: OK
2022-02-04T03:10:34.845Z CNTRLR » [Node 084] assigning return routes to the following nodes:
                                  1
2022-02-04T03:10:34.846Z CNTRLR » [Node 084] assigning return route to node 1 (attempt 1)...
2022-02-04T03:10:34.856Z SERIAL » 0x010600465401b852                                                   (8 bytes)
2022-02-04T03:10:34.857Z DRIVER » [Node 084] [REQ] [AssignReturnRoute]
                                    payload: 0x5401b8
2022-02-04T03:10:34.861Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:35.098Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:10:35.101Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:35.103Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:10:36.637Z SERIAL « 0x01050046b80004                                                     (7 bytes)
2022-02-04T03:10:36.639Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:36.657Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     184
                                    transmit status: OK
2022-02-04T03:10:36.667Z CNTRLR   [Node 084] healed successfully
2022-02-04T03:10:36.670Z CNTRLR » [Node 084] requesting node neighbors...
2022-02-04T03:10:36.685Z SERIAL » 0x01070080540000002c                                                 (9 bytes)
2022-02-04T03:10:36.687Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:10:36.692Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:36.696Z SERIAL « 0x012001800000000000000a20914ce001000000000000000000000000000000000 (34 bytes)
                                  048
2022-02-04T03:10:36.699Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:36.702Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 50, 52, 62, 65, 69, 72, 75, 76, 79, 86, 87, 88, 89
2022-02-04T03:10:36.713Z CNTRLR « [Node 084] node neighbors received: 50, 52, 62, 65, 69, 72, 75, 76, 79, 86, 87
                                  , 88, 89
2022-02-04T03:10:36.715Z CNTRLR   [Node 088] healing node...
2022-02-04T03:10:36.717Z CNTRLR » [Node 088] refreshing neighbor list (attempt 1)...
2022-02-04T03:10:36.728Z SERIAL » 0x0105004858b953                                                     (7 bytes)
2022-02-04T03:10:36.731Z DRIVER » [Node 088] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 185
2022-02-04T03:10:36.736Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:36.987Z SERIAL « 0x01050048b9212a                                                     (7 bytes)
2022-02-04T03:10:36.989Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:36.992Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   185
2022-02-04T03:10:40.369Z SERIAL « 0x01050048b92229                                                     (7 bytes)
2022-02-04T03:10:40.371Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:40.373Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   185
2022-02-04T03:10:40.379Z CNTRLR « [Node 088] neighbor list refreshed...
2022-02-04T03:10:40.380Z CNTRLR » [Node 088] Deleting SUC return route...
2022-02-04T03:10:40.392Z SERIAL » 0x0105005558ba4d                                                     (7 bytes)
2022-02-04T03:10:40.394Z DRIVER » [Node 088] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x58ba
2022-02-04T03:10:40.397Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:40.555Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:10:40.556Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:40.558Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:40.937Z SERIAL « 0x01050055ba0015                                                     (7 bytes)
2022-02-04T03:10:40.942Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:40.946Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     186
                                    transmit status: OK
2022-02-04T03:10:40.962Z CNTRLR » [Node 088] Assigning SUC return route...
2022-02-04T03:10:40.977Z SERIAL » 0x0105005158bb48                                                     (7 bytes)
2022-02-04T03:10:40.981Z DRIVER » [Node 088] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x58bb
2022-02-04T03:10:40.987Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:41.269Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:10:41.274Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:41.278Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:42.186Z SERIAL « 0x01050051bb0010                                                     (7 bytes)
2022-02-04T03:10:42.189Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:42.193Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     187
                                    transmit status: OK
2022-02-04T03:10:42.207Z CNTRLR » [Node 088] deleting return routes (attempt 1)...
2022-02-04T03:10:42.218Z SERIAL » 0x0105004758bc59                                                     (7 bytes)
2022-02-04T03:10:42.220Z DRIVER » [Node 088] [REQ] [DeleteReturnRoute]
                                    payload: 0x58bc
2022-02-04T03:10:42.224Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:42.231Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:10:42.232Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:42.235Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:10:42.886Z SERIAL « 0x01050047bc0001                                                     (7 bytes)
2022-02-04T03:10:42.888Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:42.890Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     188
                                    transmit status: OK
2022-02-04T03:10:42.899Z CNTRLR » [Node 088] assigning return routes to the following nodes:
                                  1
2022-02-04T03:10:42.900Z CNTRLR » [Node 088] assigning return route to node 1 (attempt 1)...
2022-02-04T03:10:42.914Z SERIAL » 0x010600465801bd5b                                                   (8 bytes)
2022-02-04T03:10:42.916Z DRIVER » [Node 088] [REQ] [AssignReturnRoute]
                                    payload: 0x5801bd
2022-02-04T03:10:42.919Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:43.204Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:10:43.207Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:43.211Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:10:44.185Z SERIAL « 0x01050046bd0001                                                     (7 bytes)
2022-02-04T03:10:44.187Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:44.189Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     189
                                    transmit status: OK
Part 2 and thank you.
2022-02-04T03:10:44.197Z CNTRLR   [Node 088] healed successfully
2022-02-04T03:10:44.198Z CNTRLR » [Node 088] requesting node neighbors...
2022-02-04T03:10:44.209Z SERIAL » 0x010700805800000020                                                 (9 bytes)
2022-02-04T03:10:44.211Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:10:44.215Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:44.218Z SERIAL « 0x012001800002000000000ac0910c6801000000000000000000000000000000000 (34 bytes)
                                  062
2022-02-04T03:10:44.220Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:44.236Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 10, 50, 52, 63, 64, 65, 69, 72, 75, 76, 84, 86, 87, 89
2022-02-04T03:10:44.243Z CNTRLR « [Node 088] node neighbors received: 10, 50, 52, 63, 64, 65, 69, 72, 75, 76, 84
                                  , 86, 87, 89
2022-02-04T03:10:44.244Z CNTRLR   [Node 089] healing node...
2022-02-04T03:10:44.246Z CNTRLR » [Node 089] refreshing neighbor list (attempt 1)...
2022-02-04T03:10:44.258Z SERIAL » 0x0105004859be55                                                     (7 bytes)
2022-02-04T03:10:44.259Z DRIVER » [Node 089] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 190
2022-02-04T03:10:44.263Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:44.353Z SERIAL « 0x01050048be212d                                                     (7 bytes)
2022-02-04T03:10:44.355Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:44.359Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   190
2022-02-04T03:10:53.584Z SERIAL « 0x01050048be232f                                                     (7 bytes)
2022-02-04T03:10:53.586Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:53.588Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   190
                                    update status: UpdateFailed
2022-02-04T03:10:53.601Z CNTRLR « [Node 089] refreshing neighbor list failed...
2022-02-04T03:10:53.602Z CNTRLR » [Node 089] refreshing neighbor list (attempt 2)...
2022-02-04T03:10:53.616Z SERIAL » 0x0105004859bf54                                                     (7 bytes)
2022-02-04T03:10:53.618Z DRIVER » [Node 089] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 191
2022-02-04T03:10:53.622Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:53.711Z SERIAL « 0x01050048bf212c                                                     (7 bytes)
2022-02-04T03:10:53.713Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:53.716Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   191
2022-02-04T03:10:56.674Z SERIAL « 0x01050048bf222f                                                     (7 bytes)
2022-02-04T03:10:56.676Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:56.678Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   191
2022-02-04T03:10:56.686Z CNTRLR « [Node 089] neighbor list refreshed...
2022-02-04T03:10:56.687Z CNTRLR » [Node 089] Deleting SUC return route...
2022-02-04T03:10:56.704Z SERIAL » 0x0105005559c036                                                     (7 bytes)
2022-02-04T03:10:56.706Z DRIVER » [Node 089] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x59c0
2022-02-04T03:10:56.712Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:56.921Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:10:56.923Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:56.927Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:58.313Z SERIAL « 0x01050055c0006f                                                     (7 bytes)
2022-02-04T03:10:58.315Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:58.316Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     192
                                    transmit status: OK
2022-02-04T03:10:58.332Z CNTRLR » [Node 089] Assigning SUC return route...
2022-02-04T03:10:58.345Z SERIAL » 0x0105005159c133                                                     (7 bytes)
2022-02-04T03:10:58.349Z DRIVER » [Node 089] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x59c1
2022-02-04T03:10:58.355Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:58.594Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:10:58.599Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:58.603Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:10:59.821Z SERIAL « 0x01050051c1006a                                                     (7 bytes)
2022-02-04T03:10:59.823Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:59.826Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     193
                                    transmit status: OK
2022-02-04T03:10:59.834Z CNTRLR » [Node 089] deleting return routes (attempt 1)...
2022-02-04T03:10:59.847Z SERIAL » 0x0105004759c226                                                     (7 bytes)
2022-02-04T03:10:59.849Z DRIVER » [Node 089] [REQ] [DeleteReturnRoute]
                                    payload: 0x59c2
2022-02-04T03:10:59.852Z SERIAL « [ACK]        (0x06)
2022-02-04T03:10:59.856Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:10:59.858Z SERIAL » [ACK]        (0x06)
2022-02-04T03:10:59.860Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:11:00.726Z SERIAL « 0x01050047c2007f                                                     (7 bytes)
2022-02-04T03:11:00.728Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:00.730Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     194
                                    transmit status: OK
2022-02-04T03:11:00.742Z CNTRLR » [Node 089] assigning return routes to the following nodes:
                                  1
2022-02-04T03:11:00.744Z CNTRLR » [Node 089] assigning return route to node 1 (attempt 1)...
2022-02-04T03:11:00.758Z SERIAL » 0x010600465901c324                                                   (8 bytes)
2022-02-04T03:11:00.760Z DRIVER » [Node 089] [REQ] [AssignReturnRoute]
                                    payload: 0x5901c3
2022-02-04T03:11:00.774Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:01.012Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:11:01.015Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:01.018Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:11:02.094Z SERIAL « 0x01050046c3007f                                                     (7 bytes)
2022-02-04T03:11:02.098Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:02.102Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     195
                                    transmit status: OK
2022-02-04T03:11:02.112Z CNTRLR   [Node 089] healed successfully
2022-02-04T03:11:02.114Z CNTRLR » [Node 089] requesting node neighbors...
2022-02-04T03:11:02.130Z SERIAL » 0x010700805900000021                                                 (9 bytes)
2022-02-04T03:11:02.132Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:11:02.136Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:02.141Z SERIAL « 0x01200180000000000000084091c4b800000000000000000000000000000000000 (34 bytes)
                                  0fb
2022-02-04T03:11:02.143Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:02.146Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 52, 63, 65, 69, 72, 75, 79, 80, 84, 85, 86, 88
2022-02-04T03:11:02.155Z CNTRLR « [Node 089] node neighbors received: 52, 63, 65, 69, 72, 75, 79, 80, 84, 85, 86
                                  , 88
2022-02-04T03:11:02.156Z CNTRLR   [Node 050] healing node...
2022-02-04T03:11:02.158Z CNTRLR » [Node 050] refreshing neighbor list (attempt 1)...
2022-02-04T03:11:02.171Z SERIAL » 0x0105004832c444                                                     (7 bytes)
2022-02-04T03:11:02.172Z DRIVER » [Node 050] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 196
2022-02-04T03:11:02.176Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:02.265Z SERIAL « 0x01050048c42157                                                     (7 bytes)
2022-02-04T03:11:02.267Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:02.269Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   196
2022-02-04T03:11:08.964Z SERIAL « 0x01050048c42355                                                     (7 bytes)
2022-02-04T03:11:08.967Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:08.970Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   196
2022-02-04T03:11:08.980Z CNTRLR « [Node 050] refreshing neighbor list failed...
2022-02-04T03:11:08.981Z CNTRLR » [Node 050] refreshing neighbor list (attempt 2)...
2022-02-04T03:11:09.000Z SERIAL » 0x0105004832c545                                                     (7 bytes)
2022-02-04T03:11:09.002Z DRIVER » [Node 050] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 197
2022-02-04T03:11:09.006Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:09.095Z SERIAL « 0x01050048c52156                                                     (7 bytes)
2022-02-04T03:11:09.098Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:09.106Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   197
2022-02-04T03:11:13.379Z SERIAL « 0x01050048c52255                                                     (7 bytes)
2022-02-04T03:11:13.381Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:13.384Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   197
2022-02-04T03:11:13.393Z CNTRLR « [Node 050] neighbor list refreshed...
2022-02-04T03:11:13.394Z CNTRLR » [Node 050] Deleting SUC return route...
2022-02-04T03:11:13.409Z SERIAL » 0x0105005532c65b                                                     (7 bytes)
2022-02-04T03:11:13.411Z DRIVER » [Node 050] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x32c6
2022-02-04T03:11:13.416Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:13.475Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:11:13.478Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:13.481Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:11:13.750Z SERIAL « 0x01050055c60069                                                     (7 bytes)
2022-02-04T03:11:13.753Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:13.756Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     198
                                    transmit status: OK
2022-02-04T03:11:13.766Z CNTRLR » [Node 050] Assigning SUC return route...
2022-02-04T03:11:13.780Z SERIAL » 0x0105005132c75e                                                     (7 bytes)
2022-02-04T03:11:13.782Z DRIVER » [Node 050] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x32c7
2022-02-04T03:11:13.788Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:13.878Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:11:13.880Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:13.882Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:11:15.083Z SERIAL « 0x01050051c7006c                                                     (7 bytes)
2022-02-04T03:11:15.085Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:15.087Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     199
                                    transmit status: OK
2022-02-04T03:11:15.099Z CNTRLR » [Node 050] deleting return routes (attempt 1)...
2022-02-04T03:11:15.110Z SERIAL » 0x0105004732c847                                                     (7 bytes)
2022-02-04T03:11:15.112Z DRIVER » [Node 050] [REQ] [DeleteReturnRoute]
                                    payload: 0x32c8
2022-02-04T03:11:15.116Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:15.123Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:11:15.125Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:15.128Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:11:15.921Z SERIAL « 0x01050047c80075                                                     (7 bytes)
2022-02-04T03:11:15.924Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:15.927Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     200
                                    transmit status: OK
2022-02-04T03:11:15.938Z CNTRLR » [Node 050] assigning return routes to the following nodes:
                                  1
2022-02-04T03:11:15.940Z CNTRLR » [Node 050] assigning return route to node 1 (attempt 1)...
2022-02-04T03:11:15.953Z SERIAL » 0x010600463201c945                                                   (8 bytes)
2022-02-04T03:11:15.955Z DRIVER » [Node 050] [REQ] [AssignReturnRoute]
                                    payload: 0x3201c9
2022-02-04T03:11:15.959Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:16.050Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:11:16.054Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:16.057Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:11:17.209Z SERIAL « 0x01050046c90075                                                     (7 bytes)
2022-02-04T03:11:17.211Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:17.214Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     201
                                    transmit status: OK
2022-02-04T03:11:17.224Z CNTRLR   [Node 050] healed successfully
2022-02-04T03:11:17.226Z CNTRLR » [Node 050] requesting node neighbors...
2022-02-04T03:11:17.241Z SERIAL » 0x01070080320000004a                                                 (9 bytes)
2022-02-04T03:11:17.243Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:11:17.247Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:17.250Z SERIAL « 0x0120018000000000000000008004b800000000000000000000000000000000000 (34 bytes)
                                  062
2022-02-04T03:11:17.252Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:17.254Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 72, 75, 84, 85, 86, 88
2022-02-04T03:11:17.262Z CNTRLR « [Node 050] node neighbors received: 72, 75, 84, 85, 86, 88
2022-02-04T03:11:17.263Z CNTRLR   [Node 052] healing node...
2022-02-04T03:11:17.264Z CNTRLR » [Node 052] refreshing neighbor list (attempt 1)...
2022-02-04T03:11:17.279Z SERIAL » 0x0105004834ca4c                                                     (7 bytes)
2022-02-04T03:11:17.280Z DRIVER » [Node 052] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 202
2022-02-04T03:11:17.285Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:17.373Z SERIAL « 0x01050048ca2159                                                     (7 bytes)
2022-02-04T03:11:17.375Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:17.377Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   202
2022-02-04T03:11:22.923Z SERIAL « 0x01050048ca225a                                                     (7 bytes)
2022-02-04T03:11:22.925Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:22.927Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   202
2022-02-04T03:11:22.934Z CNTRLR « [Node 052] neighbor list refreshed...
2022-02-04T03:11:22.935Z CNTRLR » [Node 052] Deleting SUC return route...
2022-02-04T03:11:22.948Z SERIAL » 0x0105005534cb50                                                     (7 bytes)
2022-02-04T03:11:22.950Z DRIVER » [Node 052] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x34cb
2022-02-04T03:11:22.956Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:23.165Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:11:23.168Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:23.171Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:11:23.542Z SERIAL « 0x01050055cb0064                                                     (7 bytes)
2022-02-04T03:11:23.545Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:23.547Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     203
                                    transmit status: OK
2022-02-04T03:11:23.555Z CNTRLR » [Node 052] Assigning SUC return route...
2022-02-04T03:11:23.568Z SERIAL » 0x0105005134cc53                                                     (7 bytes)
2022-02-04T03:11:23.570Z DRIVER » [Node 052] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x34cc
2022-02-04T03:11:23.574Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:24.054Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:11:24.057Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:24.059Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:11:25.165Z SERIAL « 0x01050051cc0067                                                     (7 bytes)
2022-02-04T03:11:25.167Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:25.171Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     204
                                    transmit status: OK
2022-02-04T03:11:25.183Z CNTRLR » [Node 052] deleting return routes (attempt 1)...
2022-02-04T03:11:25.193Z SERIAL » 0x0105004734cd44                                                     (7 bytes)
2022-02-04T03:11:25.194Z DRIVER » [Node 052] [REQ] [DeleteReturnRoute]
                                    payload: 0x34cd
2022-02-04T03:11:25.200Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:25.204Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:11:25.205Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:25.208Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:11:27.408Z SERIAL « 0x01050047cd0070                                                     (7 bytes)
2022-02-04T03:11:27.410Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:27.413Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     205
                                    transmit status: OK
2022-02-04T03:11:27.427Z CNTRLR » [Node 052] assigning return routes to the following nodes:
                                  1, 76
2022-02-04T03:11:27.429Z CNTRLR » [Node 052] assigning return route to node 1 (attempt 1)...
2022-02-04T03:11:27.464Z SERIAL » 0x010600463401ce44                                                   (8 bytes)
2022-02-04T03:11:27.466Z DRIVER » [Node 052] [REQ] [AssignReturnRoute]
                                    payload: 0x3401ce
2022-02-04T03:11:27.470Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:27.945Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:11:27.950Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:27.954Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:11:29.793Z SERIAL « 0x01050046ce0072                                                     (7 bytes)
2022-02-04T03:11:29.796Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:29.800Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     206
                                    transmit status: OK
2022-02-04T03:11:29.824Z CNTRLR » [Node 052] assigning return route to node 76 (attempt 1)...
2022-02-04T03:11:29.845Z SERIAL » 0x01060046344ccf08                                                   (8 bytes)
2022-02-04T03:11:29.847Z DRIVER » [Node 052] [REQ] [AssignReturnRoute]
                                    payload: 0x344ccf
2022-02-04T03:11:29.852Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:30.440Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:11:30.445Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:30.449Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:11:32.183Z SERIAL « 0x01050046cf0073                                                     (7 bytes)
2022-02-04T03:11:32.184Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:32.187Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     207
                                    transmit status: OK
2022-02-04T03:11:32.197Z CNTRLR   [Node 052] healed successfully
2022-02-04T03:11:32.199Z CNTRLR » [Node 052] requesting node neighbors...
2022-02-04T03:11:32.212Z SERIAL » 0x01070080340000004c                                                 (9 bytes)
2022-02-04T03:11:32.213Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:11:32.221Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:32.225Z SERIAL « 0x0120018000000000000000001100a801000000000000000000000000000000000 (34 bytes)
                                  0e6
2022-02-04T03:11:32.228Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:32.232Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 65, 69, 84, 86, 88, 89
2022-02-04T03:11:32.260Z CNTRLR « [Node 052] node neighbors received: 65, 69, 84, 86, 88, 89
2022-02-04T03:11:32.261Z CNTRLR   [Node 080] healing node...
2022-02-04T03:11:32.264Z CNTRLR » [Node 080] refreshing neighbor list (attempt 1)...
2022-02-04T03:11:32.281Z SERIAL » 0x0105004850d032                                                     (7 bytes)
2022-02-04T03:11:32.284Z DRIVER » [Node 080] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 208
2022-02-04T03:11:32.289Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:32.379Z SERIAL « 0x01050048d02143                                                     (7 bytes)
2022-02-04T03:11:32.381Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:32.384Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   208
2022-02-04T03:11:39.216Z SERIAL « 0x01050048d02341                                                     (7 bytes)
2022-02-04T03:11:39.221Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:39.223Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   208
2022-02-04T03:11:39.231Z CNTRLR « [Node 080] refreshing neighbor list failed...
2022-02-04T03:11:39.232Z CNTRLR » [Node 080] refreshing neighbor list (attempt 2)...
2022-02-04T03:11:39.244Z SERIAL » 0x0105004850d133                                                     (7 bytes)
2022-02-04T03:11:39.246Z DRIVER » [Node 080] [REQ] [RequestNodeNeighborUpdate]
                                    callback id: 209
2022-02-04T03:11:39.250Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:39.600Z SERIAL « 0x01050048d12142                                                     (7 bytes)
2022-02-04T03:11:39.603Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:39.607Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   209
2022-02-04T03:11:44.564Z SERIAL « 0x01050048d12241                                                     (7 bytes)
2022-02-04T03:11:44.566Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:44.567Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
                                    callback id:   209
2022-02-04T03:11:44.581Z CNTRLR « [Node 080] neighbor list refreshed...
2022-02-04T03:11:44.584Z CNTRLR » [Node 080] Deleting SUC return route...
2022-02-04T03:11:44.596Z SERIAL » 0x0105005550d22d                                                     (7 bytes)
2022-02-04T03:11:44.600Z DRIVER » [Node 080] [REQ] [DeleteSUCReturnRoute]
                                    payload: 0x50d2
2022-02-04T03:11:44.608Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:45.145Z SERIAL « 0x0104015501ae                                                       (6 bytes)
2022-02-04T03:11:45.148Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:45.152Z DRIVER « [RES] [DeleteSUCReturnRoute]
                                    was executed: true
2022-02-04T03:11:45.505Z SERIAL « 0x01050055d2007d                                                     (7 bytes)
2022-02-04T03:11:45.507Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:45.511Z DRIVER « [REQ] [DeleteSUCReturnRoute]
                                    callback id:     210
                                    transmit status: OK
2022-02-04T03:11:45.521Z CNTRLR » [Node 080] Assigning SUC return route...
2022-02-04T03:11:45.535Z SERIAL » 0x0105005150d328                                                     (7 bytes)
2022-02-04T03:11:45.538Z DRIVER » [Node 080] [REQ] [AssignSUCReturnRoute]
                                    payload: 0x50d3
2022-02-04T03:11:45.543Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:45.882Z SERIAL « 0x0104015101aa                                                       (6 bytes)
2022-02-04T03:11:45.887Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:45.890Z DRIVER « [RES] [AssignSUCReturnRoute]
                                    was executed: true
2022-02-04T03:11:47.667Z SERIAL « 0x01050051d30078                                                     (7 bytes)
2022-02-04T03:11:47.669Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:47.671Z DRIVER « [REQ] [AssignSUCReturnRoute]
                                    callback id:     211
                                    transmit status: OK
2022-02-04T03:11:47.681Z CNTRLR » [Node 080] deleting return routes (attempt 1)...
2022-02-04T03:11:47.702Z SERIAL » 0x0105004750d439                                                     (7 bytes)
2022-02-04T03:11:47.704Z DRIVER » [Node 080] [REQ] [DeleteReturnRoute]
                                    payload: 0x50d4
2022-02-04T03:11:47.708Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:48.246Z SERIAL « 0x0104014701bc                                                       (6 bytes)
2022-02-04T03:11:48.248Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:48.251Z DRIVER « [RES] [DeleteReturnRoute]
                                    has started: true
2022-02-04T03:11:48.776Z SERIAL « 0x01050047d40069                                                     (7 bytes)
2022-02-04T03:11:48.779Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:48.781Z DRIVER « [REQ] [DeleteReturnRoute]
                                    callback id:     212
                                    transmit status: OK
2022-02-04T03:11:48.794Z CNTRLR » [Node 080] assigning return routes to the following nodes:
                                  1
2022-02-04T03:11:48.795Z CNTRLR » [Node 080] assigning return route to node 1 (attempt 1)...
2022-02-04T03:11:48.807Z SERIAL » 0x010600465001d53b                                                   (8 bytes)
2022-02-04T03:11:48.809Z DRIVER » [Node 080] [REQ] [AssignReturnRoute]
                                    payload: 0x5001d5
2022-02-04T03:11:48.815Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:49.151Z SERIAL « 0x0104014601bd                                                       (6 bytes)
2022-02-04T03:11:49.153Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:49.155Z DRIVER « [RES] [AssignReturnRoute]
                                    has started: true
2022-02-04T03:11:50.582Z SERIAL « 0x01050046d50069                                                     (7 bytes)
2022-02-04T03:11:50.584Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:50.587Z DRIVER « [REQ] [AssignReturnRoute]
                                    callback id:     213
                                    transmit status: OK
2022-02-04T03:11:50.594Z CNTRLR   [Node 080] healed successfully
2022-02-04T03:11:50.599Z CNTRLR » [Node 080] requesting node neighbors...
2022-02-04T03:11:50.616Z SERIAL » 0x010700805000000028                                                 (9 bytes)
2022-02-04T03:11:50.620Z DRIVER » [REQ] [GetRoutingInfo]
2022-02-04T03:11:50.625Z SERIAL « [ACK]        (0x06)
2022-02-04T03:11:50.630Z SERIAL « 0x01200180000000000000008011000001000000000000000000000000000000000 (34 bytes)
                                  0ce
2022-02-04T03:11:50.635Z SERIAL » [ACK]        (0x06)
2022-02-04T03:11:50.639Z DRIVER « [RES] [GetRoutingInfo]
                                    node ids: 64, 65, 69, 89
2022-02-04T03:11:50.649Z CNTRLR « [Node 080] node neighbors received: 64, 65, 69, 89
2022-02-04T03:11:50.651Z CNTRLR   Healing sleeping nodes in parallel. Wake them up to heal.
2022-02-04T03:13:52.218Z SERIAL « 0x0120000400551a9f033100986c908d8429c5b39b59537087e08315edd33df570f (34 bytes)
                                  c61
2022-02-04T03:13:52.247Z CNTRLR   [Node 085] [~] [Meter] value[65537]: 2.304 => 2.307               [Endpoint 0]
2022-02-04T03:13:52.254Z SERIAL » [ACK]        (0x06)
2022-02-04T03:13:52.263Z DRIVER « [Node 085] [REQ] [ApplicationCommand]
                                  └─[Security2CCMessageEncapsulation]
                                    │ sequence number: 49
                                    └─[MeterCCReport]
                                        type:        Electric
                                        scale:       kWh
                                        rate type:   Consumed
                                        value:       2.307
                                        time delta:  3244 seconds
                                        prev. value: 2.304
2022-02-04T03:13:52.872Z SERIAL « 0x011c00040055169f033200cf0b65757cc212f2f9c49c64ed7ec1131e7862      (30 bytes)
2022-02-04T03:13:52.877Z CNTRLR   [Node 085] [~] [Meter] value[66049]: 5.3 => 5.3                   [Endpoint 0]
2022-02-04T03:13:52.879Z SERIAL » [ACK]        (0x06)
2022-02-04T03:13:52.883Z DRIVER « [Node 085] [REQ] [ApplicationCommand]
                                    │ sequence number: 50
                                    └─[MeterCCReport]
                                        type:       Electric
                                        scale:      W
                                        rate type:  Consumed
                                        value:      5.3
                                        time delta: 0 seconds
Are you using a USB extension cord? Adding one to my setup made a big difference.
Will take a look! Give me a bit to review here and I’ll see if anything looks off. Did they all heal successfully? Any performance change?
Man this all looks pretty solid. Took a second try on a few nodes but all of them successfully took the heal.
Any log issues like missing devices or zwave js log notes?
More than 1 at a time usually means a spammed network I agree. Pulling the air gaps on all switches for a minute or so might help as well.
Thanks for looking. I did air gap all the switches… not sure where it went wrong. Excluding the switches were the only thing that could get my lights to turn off and on at the switch. Couldn’t find a single culprit causing it.
My raspberry pi setup is pretty tired (more me, than the pi.) Decided to do a full overhaul and clean install on my Synology NAS.
I’m using zwavejs2mqtt instead of the official zwave-js install. Hopefully a better logging system i’ll be able to figure out what’s going on if it happens in a month.
