Red mmwave "motion detection" always "detected"
There is a distinct difference between the raw motion entity and the target tracking presence entity exposed to smart home platforms like Home Assistant:
motion_detection
  • What it indicates: Raw, unfiltered motion detected anywhere within the radar’s maximum physical reach (~20+ feet).
  • Does it obey P101–P106 / P117? No. It triggers whenever movement is detected within the hardware’s full field of view, irrespective of your defined reporting boundaries.
mmwave_person_in_the_reporting_area
  • What it indicates: Target presence strictly within your configured 3D room boundary.
  • Does it obey P101–P106 / P117? Yes. It evaluates spatial X/Y/Z coordinates and will only trip when a detected target falls within those defined bounds.
Which one should you use?
  • For lighting & room automations: Use mmwave_person_in_the_reporting_area. This prevents false triggers from hallway traffic, movement past open doorways, or motion outside room boundaries.
  • For security or broad coverage: Use motion_detection if you want the switch to react to any movement within its hardware range, regardless of room bounds.
When the motion_detection entity becomes permanently latched on “Detected” after 5 to 10 days of normal operation (and only resets after a physical air-gap power cycle), you are dealing with a known firmware/hardware buffer issue on early builds of the Inovelli mmWave switches .
Primary Cause: Z-Wave Chip Buffer Overrun
The internal switch hardware uses a dedicated HLK mmWave radar module that communicates with an onboard Z-Wave or Zigbee transceiver chip.
In high-traffic areas or environments where micro-motions are constantly evaluated, the mmWave radar module sends a continuous stream of presence data. Over a span of several days (typically 5 to 10), the receiving buffer on the main processor experiences a memory stack overflow. Once this buffer fills up, the Z-Wave chip freezes its last known binary state which is usually “Detected” and stops processing new state updates.
Pulling the air-gap tab cuts power to the memory state, which clears the stuck buffer and restores normal functionality for another few days.
How to Fix It
1. Update the Switch Firmware
Inovelli engineering identified this buffer crash and pushed a firmware fix to increase buffer handling and rate-limit presence packet spamming.
  • For Red Series (Z-Wave / VZW32-SN): Update your switch firmware to v2.02 or higher via Z-Wave JS / Z-Wave JS UI.
2. Fine-Tune Parameter Settings (To reduce packet spam)
If you cannot update the firmware immediately, you can slow down how quickly the buffer fills up by adjusting a few configuration parameters:
  • Increase Detection Timeout (Parameter 114): If set to a very low value (e.g., 5–10 seconds), the radar rapid-fires detected and cleared state changes every time someone shifts position, which accelerates the memory leak. Set this to 30–60 seconds.
  • Reduce Sensitivity (Parameter 112): Change from High (2) to Medium (1) or Low (0). This stops the sensor from constantly tracking minute environmental noise (like HVAC vents or pipe vibrations) when the room is empty.
  • Set an Interference Zone (Parameter 111): If the radar is tracking a static moving object (e.g., a ceiling fan or air purifier), set Parameter 111 to 1 while leaving the room empty so the radar learns to ignore background noise
