So on the zwave docs the acceptable notification paramerter is 83823359, but using the notification calculator Inovelli Switch Toolbox you can get a larger value when using the pulse type, for example I used to use 100600088. I recently moved to OpenZWave dameon for to interface with Home Assistant and they enforce the max stated in the docs and don’t even attempt to send the config param. @EricM_Inovelli. This used to work with built In zwave integration for zwave but recently moved to OpenZWave dameon.
Thanks @nathanfiscus had fixed this in our repository but I had not pushed it up to the open-zwave repository. I just submitted a pr for it.
