I messaged Scott on the Hubitat Community website telling him I could not pair my two new RED dimmers I purchased from Amazon. He said send them back to Amazon and mark them defective which I did. I ordered two more directly from Inovelli and the same problem…they refused to pair after many attempts to exclude and include. Next I tried a BLACK series dimmer and it paired perfectly. This is the second BLACK dimmer that paired fine. I tried factory resetting the RED dimmers but no help. I am at a loss on this and my faith in this company is fading. I want to get someone there to take these two new dimmers and either give me my money back or find a solution. I have experience in home automation with all types of devices and this is the first time having such difficulty.
@neutronspin I had a couple that would not pair. Try factory resetting them by holding config button pressed for 20+ seconds. Then leave them powered up for 5-10 mins. Try pairing again after steps above are completed. All my Red switches have paired to my Hubitat device.
Thanks…I tried factory resetting but no help. I did not leave them on for that long. Will try again and leave them powered up for 10 minutes. Also do you need a load connected to them?
@neutronspin, Second what @harjms said. I’m sure you checked this, but did the signal strength meter turn green? I have yet to have a problem including any of the Inovelli switches… Even one that I thought would be too far away.
I didn’t have the load on. I literally just left them for a few minutes and came back to include them. No issues. I literally had two other non dimmer red switches next to it that had zero inclusion issues so I knew range was adequate.
Okay, a “Hail Mary” here, try to do a Z-Wave repair after factory resetting the Reds. Then try including them. I’ve had to do this with a couple of monoprice sensors before they would include. Even when 5’ from the hub.
Yippee!!!..Did another factory reset…waited 10 minutes and only tried six times and it finally was discovered…For some reason the RED dimmers must be a little fussy on the pairing. Wouldn’t think the firmware would take that long to update…Anyhow I am elated over this and thanks to all on here for the help…more Dimmers to follow…
