I’m running home assistant with zwave-js. When I add the switch, it’s detected as a black series (LZW30), when I interview the switch. Any ideas as to what I can do for it to show up correct?
Thanks.
Thanks.
Why not Zwavejs2Mqtt? It doesn’t need MQTT, and seems to be the current preferred Z-Wave utility in Home Assistant.
I have four LZW30SN’s on Home Assistant with no problems…
Curious if using Zwave2Mqtt let you add these switches as LZW30SN’s???
Have you updated the firmware? Possibly got the wrong one? Have you checked the faceplate to confirm it is a Red?
