Hello I recently moved and when installing the switch to the new location it makes a buzzing sound when the switch is on. Its a 2 gang switch.
Neutral or non-neutral?
Did you test to determine which was the line and which was the load?
Pull the switch and double check to make sure that the connections are secure.
Neutral, I tested the line and Load and made sure the line is in the correct spot, the switch is a 2-gang switch, I’ve tried swapping the transfer and load wires and fixed a loose ground wire, the bussing is not as loud as it was, but still there, any more suggestions?
Do you mean this switch is part of a 3-way, i.e. two switches for one set of lights? If so, did you check the other switch for loose connections?
What bulbs are you using?
Not sure which generation red you have, but if it’s a Gen 3, try switching to trailing edge.
