Hello. I installed new Red switches a couple of weeks ago and I’m loving them. They look so fancy and has a ton of features. Love the smart bulb mode.
One of my switches though intermittently appears as dead on my Home Assistant Z-wave JS UI. When I press the switch and turn the light on, it becomes “alive” again.
This switch is not the farthest from my hub. I have 2 other switches that are farther and they have not been acting up.
This switch is connected to the Zooz 800 Series Z-Wave Long Range USB Stick ZST39 LR using the latest firmware.
Is there anything I can do to make it not “die” intermittently? Do you think I got a bad switch?
Have you done a heal or I think it’s now called rebuild routes on the network. If your network is healthy then it should work for all devices without getting failures. After adding a bunch of devices, I had to do it for some individually first before it’s begin to work for the whole network. Things seemed to work better after doing it.
