NOTE: This is a work in progress – I should be finished in a couple of days.
While we try to keep this article up to date, it’s often hard due to the many updates to our firmware. If any updates/edits need to be made to this article, please comment here (https://community.inovelli.com/t/wiki-general-feedback-suggestions-thread/7399) and reference this thread or shoot any staff member a PM.
Overview
This article will list out all firmware changelogs for Inovelli products as well as reference the current production and beta firmware versions. For information on how to update your firmware or to find the firmware files, please reference the resources section at the bottom of the page.
To navigate the changelog, please click on the product category (ie: switches, lighting, sensors, etc.) located at the far right of the screen (on PC) or at the bottom (on mobile) and then find the product within the category.
Switches
Black Series
LZW30 - On/Off
Please see the latest firmware information below:
- Production Version = 1.20
- Beta Version = 1.22
Below you will find the changelogs for each version as well as the current parameter settings. It’s important to note that sometimes parameters are added and removed so please check under the changelog to ensure all parameters you are interested in are available before upgrading.
V1.22 - Released: May 10, 2021 (Beta)
Changelog
NOTE: Scroll right/left to see all the information
| Category | Details | Notes |
| Enhancements | N/A | N/A |
| Bug Fixes | Fixed the bug that the V1 version of Protection Set Command would cause RF state of Protection to become enabled. | This mostly affected Home Assistant users as it is still using V1 of this command class. |
| Removals | N/A | N/A |
| Important Reminders | N/A | N/A |
| ____________________ | _____________________________ | _____________________________ |
Parameters
| Parameter # | Local Config | About | Description | Action | Range | Default | Size (Bytes) |
| 1 | Yes | Power On State | When power is restored, the switch reverts to either On, Off, or Last Level | 0 = Returns to Prior State 1 = On 2 = Off |
0-2 | 0 | 1 |
| 2 | Yes | Invert Switch | Inverts the switch (Tap Down = On, Tap Up = Off) | 0 = Disabled 1 = Enabled |
0-1 | 0 | 1 |
| 3 | No | Auto Off Timer | Automatically turns the switch off after x amount of seconds | 0 = Disabled 1 = 1 second 32767 = 32767 seconds |
0-32767 | 0 | 2 |
| 4 | No | Association Behavior | When should the switch send commands to associated devices | 01 = Local 02 = 3-Way 03 = 3-Way & Local 04 = Z-Wave HUB 05 = Z-Wave HUB & Local 06 = Z-Wave HUB & 3-Way 07 = Z-Wave HUB & Local & 3-Way 08 = Timer 09 = Timer & Local 10 = Timer & 3-Way 11 = Timer & 3-Way & Local 12 = Timer & Z-Wave HUB 13 = Timer & Z-Wave HUB & Local 14 = Timer & Z-Wave HUB & 3-Way 15 = All |
0-15 | 15 | 1 |
| 5 | Yes | LED Indicator Color | This will set the default color of the LED Bar | Calculated by using a hue color circle (Value / 255 * 360). See Nathan Fiscus’s Inovelli Switch Toolbox for more info | 0-255 | 170 (Blue) |
2 |
| 6 | Yes | LED Indicator Intensity | This will set the intensity of the LED bar (ie: how bright it is) | 0 = Off 1 = Low 5 = Medium 10 = High |
0-10 | 5 | 1 |
| 7 | Yes | LED Indicator Intensity (When Off) | This is the intensity of the LED bar when the switch is off | 0 = Off 1 = Low 5 = Medium 10 = High |
0-10 | 1 | 1 |
| 13 | Yes | Special Light Type | Use if your Multi-Light auto-detection is not working. NOTE: This is typically not needed to manually configure as this switch has, “auto-detection”. However, in rare cases this parameter is needed if 3-Way is not working. | 0 = Auto-Detect 1 = Special Load Type |
0-1 | 1 | 1 |
| 51 | No | Instant-On Optimization | Removes the 700ms delay for turning on/off the switch. NOTE: If this is turned on, you will lose scene control on buttons 2-6. | 0 = Instant-On 1 = 700ms Delay |
0-1 | 1 | 1 |
| _______ | ___ | ___________________________________ | _____________________________ | _________________________________ | _________ | _________ | _________ |
V1.21 - Released: August 17, 2020
Changelog
| Enhancements | S2 inclusion optimization for 700 series hubs. | N/A |
| Bug Fixes | N/A | N/A |
Parameters
0-2 | 0 | 1 |
0-1 | 0 | 1 |
0-32767 | 0 | 2 |
0-15 | 15 | 1 |
2 |
0-10 | 5 | 1 |
0-10 | 1 | 1 |
0-1 | 1 | 1 |
0-1 | 1 | 1 |
V1.20 - Released: July 14, 2020 (Production)
Changelog
| Enhancements | Optimizes Z-Wave exclusion during mass production. Intended for quality testing after assembly. | N/A |
Parameters
0-2 | 0 | 1 |
0-1 | 0 | 1 |
0-32767 | 0 | 2 |
0-15 | 15 | 1 |
2 |
0-10 | 5 | 1 |
0-10 | 1 | 1 |
0-1 | 1 | 1 |
0-1 | 1 | 1 |
V1.19 - Released: July 06, 2020
Changelog
| Enhancements | Add parameter 51, to enable instant on (ie: disable the 700ms delay). Note, if you disable the delay, it will also disable scene control except for Button 1 (ie: tap up 1x or tap down 1x) and button 7 (config button). All other buttons (2-6) will be disabled. Added the LED color, “White” when parameter 5 is set to 255. |
N/A |
Parameters
0-2 | 0 | 1 |
0-1 | 0 | 1 |
0-32767 | 0 | 2 |
0-15 | 15 | 1 |
2 |
0-10 | 5 | 1 |
0-10 | 1 | 1 |
0-1 | 1 | 1 |
0-1 | 1 | 1 |
V1.17 - Released: May 01, 2020
Changelog
| Bug Fixes | Fixed: when a device is not on a network, a factory reset by holding down the config button for 20 seconds does not reset the configuration. Fixed: multiple switches blink green (like they were excluded) when more than one switch is not on a z-ware network and one of those switches is excluded. Fixed: when the load is off, setting parameter 3 (auto off timer) problem. Fixed: when the parameter 3 is set from non-zero to zero, it is immediately closed if the load is on. |
For the 3rd fix (load off, parameter 3) sometimes the timer would be incorrect the first time the load turned off. |
| Important Reminders | Features lost if downgrading to this firmware version | If you downgrade to this firmware, you will lose parameter 51 (instant-on) and the ability to set your LED bar to white |
Parameters
0-2 | 0 | 1 |
0-1 | 0 | 1 |
0-32767 | 0 | 2 |
0-15 | 15 | 1 |
2 |
0-10 | 5 | 1 |
0-10 | 1 | 1 |
0-1 | 1 | 1 |
V1.16 - Released: April 06, 2020
Changelog
| Bug Fixes | Fixed: state sometimes not being restored properly when local protection is enabled. Fixed: the issue when more than one device is associated and the switch is in S0 mode, the second device does not get commands. Fixed: the bulb would occasionally blink once to OFF when re-powered if connected to a traditional switch. Fixed: the parameter 7 value not being able to be set to 10 during local config mode. Fixed: when the switch is ON and associated bulb is OFF, pressing the Aux switch UP would not turn on the associated bulb. Fixed: when local protection is enabled, the settings for “State after power restored” did not work. Fixed: switch responding to Basic Set with Switch Binary Report. It now responds with a Basic Report when a Basic Set is sent and a Switch Binary Report when a Switch Binary Set is sent. |
| Important Reminders | Features lost if downgrading to this firmware version | If you downgrade to this firmware, you will lose parameter 51 (instant-on), the ability to set your LED bar to white, and parameter 13 (special load detection) |
Parameters
0-2 | 0 | 1 |
0-1 | 0 | 1 |
0-32767 | 0 | 2 |
0-15 | 15 | 1 |
2 |
0-10 | 5 | 1 |
0-10 | 1 | 1 |
