Reusing firmware update LED effect on blue switch
Has anyone figured out to recreate the firmware update effect seen on the blue leds? I’m trying to reuse that effect as a timed notification.
The hub that the switch is connected to can send a command that will replica that and can also initiate a bunch of other effects. If you share the hub model that you use, someone should be able to help with how to do it with it.
As far as I know, this cannot be done without a connected hub (neither can it be done with Alexa).
I’m currently using z2m with a tubeZ coordinator. I already have other types of led effects/notifications setup. I think I have a general idea in my head on how to implement it just curious if anyone has attempted it.
Got it - I’m using Hubitat, so not sure how it can be done with Z2m. I suspect others might…
