Alright thank you guys, I had checked settings (with the wrong dth) and forgot to check again with the new one. Thanks for help, everything looks really good so far. Now I just need to figure out how I am going to trigger all cool new things
Heads up, for HomeAssistant the install guide has a typo for the curl command in step #4 of the āDownloading the Config Filesā section:
Current:
curl -o open-zwave/config/inovelli/lzw36.xml https://raw.githubusercontent.com/InovelliUSA/OpenZWave/master/config/inovelli/lzw45.xml
Fix:
curl -o open-zwave/config/inovelli/lzw45.xml https://raw.githubusercontent.com/InovelliUSA/OpenZWave/master/config/inovelli/lzw45.xml
Took me a sec to figure this out, was rapidly going throw guide and getting stuff setup on HASS. My issue now though is I donāt have a light entity? Only the following:
Anyone have any tips?
Hey all ā sorry for the delay on the instructions and setup pages.
I believe all but Hubitat pages are now up and available (Nathan is scrambling on HE) I knocked them out:
I need to finish showing how to setup the animations for ST, which I should be finished here in an hour or so. Done.
Again, thanks for your patience.
Iāll respond more to the rest of the comments likely later tonight or tomorrow ā weāre excited to get these out!
Mine is ārunning lateā also.
Got mine today. Iām with @Snell on it blinding when powered on. I wasnāt even standing that close when it came on and Iām seeing spots. Got it added to my HE but Iām totally lost as to what some of these parameters mean. Iāll need to mess around with it when I have some time to dedicate to sit and tinker. Would love to see some tutorials on basic usage within rule machine and then I could probably figure out out from there. I will say after messing with the colors on the device page, thereās some pretty good depth of color but thereās also some colors that donāt even remotely look the way they do on the device page. I had a red selected, like the red on the box this thing came in and the strip was completely purple. Maybe Iām just an idiot (entirely possible) and I have no idea what Iām doing but I figure I could at least get the colors correct. Will do more testing in the future
I will add that so far, I actually DISLIKE the manner in which this dims/powers on/off. Essentially itās āstutteringā itās way to the desired brightness/power state. Even setting the rate to a value of 1, I can see the stuttering effect. I personally wouldāve liked to see a smooth ramp like a curve rather than a step effect to get it to transition. Not sure if thatās something that can be addressed in the future with firmware updates, but something I would personally like to see
yeah tutorial on most of the settings would be great for us non tech savy users lol
Good evening everyone ā what a day.
@Snell & @jason.motwani ā just wanted to say thanks so much for the feedback, it really means a lot! Iāve started a page that will capture all this as we start the process of improving the firmware. Feel free to add anything there that I missed.
We will continue to flush out all the 404 errors and QR code mishaps over the next couple of days.
@adriang809 & @jason.motwani ā definitely weāll get a tutorial of what all the settings are/mean shortly. Unfortunately Brianna is out of the office (sheās our videographer), but when sheās back, we plan on launching a slew of videos that explains everything across the various hubs.
I think Iāve knocked out most of the info for SmartThings (EDIT: And Hubitat), which should be fairly similar to Hubitat in terms of usage, so if you want to take a look, feel free to do so here:
Weāll be adding more and more as time goes by and/or people ask us for tutorials.
Thanks again for your support and patience and have an awesome day!
On the Vera page, thereās a notice with a link to a thread about changing the device type for the bulbs. Is that germane to the LED strip or a copy/paste artifact?
Is anyone else using this on Vera? I canāt get parameters to update.
@EricM_Inovelli ā can you speak to this a bit? Iām assuming itās just in regards that you use the same steps to add color to the lightstrip as you do to the bulbs?
@apd183 ā youāre talking about this, correct?
These lights are amazing! Any chance we will see the option to buy more of the 6inch extensions?
I have already ālostā both of mine. I made the mistake of showing one off to the family last night and my wife designated one for one room and a daughter claimed the other for her room⦠No fair.
Yes thatās the message I was referring to. Thanks.
6 inch extensions are available now on the website!
Yeah, that is what I have had to do to get color support for our bulbs and light strip in Vera. Maybe it isnāt necessary anymore with a newer version of Vera? When I included it a few weeks ago I didnāt see color and temperature support until I took these steps.
Iām happy to report that my lightstrip arrived today and I really like it. It paired up with Smartthings easily and after I changed the device handler manually I was able to access all of the functions. I have a couple of preliminary questions before I get a chance to really dive into it.
Is there any documentation as to what the āCustom Effectā numbers mean?
Will the extensions be available in sizes other than 4 foot? I would like some shorter non-lighted strips so that I can go up the wall between shelves and have the lights on the bottom of the shelves only.
Is āindividually addressableā a LED strip term or does this allow us to individually set each LED individually, like if I want the 42nd LED to be blue.
Great work! I will definitely be getting another controller and some extensions after I figure out how I want to stick everything. Keep it up, love your stuff!
There is some detail here, although itās a bit cryptic.
You can use @nathanfiscusā tool to derive values to use for the Custom Effects. Nathan should be able shed some light on the parameters. Also, I think Inovelli is working on a similar tool.
Naturally with Vera, it worked the third time I tried it! Canāt wait to find a new hubā¦
Might want to add a note to the callout indicating the linked thread is for the bulbs but also works for the strips. When it didnāt work the first time I started doubting it.
Edit: I just realized it linked to the forum. Posted my experience there to hopefully help others.
Yes, it means that the controller can set the color and brightness of each RGB LED individually and independently of the other RGB LEDs on the strip (The white LEDs are not individually addressable, so all of the white LEDs are set to the same brightness along the entire strip when those are used).
However, with the current firmware thereās no way for a user to specify to the controller how they want each LED set on a per-LED basis. Replies earlier in this thread suggest that Inovelli is looking at how they can best add this in a future firmware update.
TL;DR: The hardware can do what you want, but the software is still being worked on.
Light strips received and really loving them so far. Looking at placing another order to go over our kitchen cabinets. One issue though, where our fridge bumps out the cabinet does as well. I would like to follow the cabinets overhead but I donāt see any left angle connectors, only right. Are there any plans on left angle or does anyone have any advice on how to accomplish what I am looking to do?
