Configuration: Hubitat C-8 Pro in one corner of the ground floor of a 2-story 3800 sf house with basically a box shape, with drywall and wood stud interior construction. Latest firmware installed (2.3.9.193). Paired Zigbee units include 43 mains-powered Leviton Zigbee dimmers or switches, 13 mains-powered plugin outlets (mix of Sengled, GE, and Leviton), and 1 Aeotec range extender at the opposite corner of the house from the hub (installed to reach a shed nearby).
In addition, I have 1 working and paired Inovelli Blue 2-1 (dimmer configuration), and 4 non-pairing (but locally working) Inovelli Blue 2-1’s.
The 4 non-pairing IB’s are at these distances: 16 feet (2 IB’s), 25 feet, 60 feet. ALL of these IB’s are within 20 feet of 6 or more paired mains-powered Zigbee devices, and within 5 feet or less of at least one mains-powered Zigbee device.
The one paired IB is about 6 feet from the hub. The “Check Zigbee Network Strength at your Switches location” button combination shows green (strong signal) for that unit. It was the first IB installed, and based on its capabilities, I bought 40 more IB’s direct from Inovelli that arrived Oct. 7, 2024 (so I’m hoping that they cannot be the known bad types from 2 or 3 years ago).
ALL of the other installed 4 IB’s show red for network strength. NONE will pair, although on occasion each has been seen but pairing failed. If the reading is correct, it looks like the IB’s won’t pair through other mains-powered routers??
Besides “regular” pairing, I’ve tried resetting each device to factory status, pairing while trying to avoid Zigbee 3.0 repeaters, and pairing while exchanging keys in the clear. No joy. I’ve tried increasing the Zigbee radio power – I was at level 8 before installing the 4 recalcitrant IB’s, and tried levels 12, 16, and 20: no joy.
Any constructive suggestions before I return all 40 IB units? I REALLY want these units to work!
