Are those switches? i.e. LZW30-SNs If so, they are ON/OFF Switches, not dimmers. They won’t have a smart bulb mode. See my comment above.
Not sure I understand the issue, though . . .
No option. Am I making things up?? I thought there was a smart bulb mode before the switch from groovy to edge drivers.
Bry - I thought there was a smart bulb mode for the on/off. If no smart bulb mode, do you set up the button/paddles to control the smart bulb?
I don’t recall if there was or wasn’t a smart bulb mode under Groovy, but SBM for a switch makes no sense. You just need to Disable Local Control.
There are two components to the SBM when used with a DIMMER and a smart bulb:
When you use a SWITCH with a smart bulb, there is no need for #1. Switches always output full power, so #1 doesn’t apply to a switch. That leaves #2, which is the same as Disabling Local Control.
So if you have a smart bulb physically wired to a SWITCH (i.e. not a DIMMER) then turn the switch on and Disable Local Control. The smart bulb will then be receiving full power and phyical presses of the paddle with not cut the power to the wired load.
You can then control the bulb via automations initiated by the multi-tap functions of the switch. Or, if your bulb and switch are running the same protocol, you can bind or associate them. Personally, I would just use a Routine initiated by a tap or multi-taps and call it good.
I looked in the groovy driver and it didn’t reference smart bulb mode either. I promise I’m not trying to be difficult, I honestly couldn’t remember and just can’t find any reference to it on the LZW30 devices.
EricM and Bry,
I really appreciate the assistance. I really love the hell out of inovelli products. I’m happy you guys make such well thought out oroducts. I’ll use the multi-tap and call it good.
Hi all, Merry Christmas! For those with the blue series 2-1 switches and fan switches, does anyone have over ~32 installed and are having the driver crash?
I’m on a v2 hub with very few custom drivers, but with over 50 Inovelli switches. Im only able to use the Blue driver up to around 30 to 32 devices before the driver on every Inovelli blue device starts crashing rendering all switches dead. I have to switch back to ST’S stock driver to get things to stop crashing so they start working again. I have a lot of devices, but almost all are using stock drivers, and my hubs memory is reporting as ok. This started a few months ago and didn’t start with a firmware update either.
Is anyone else having similar issues like this? I am working with Inovelli on this since August, but im not sure if it is an isolated issue with me, or broader. I’m also considering writing my own “lite” driver and splitting up the switch and fan into separate drivers.
I’m switching over some of my Blue switches (not the fan switches) back to Inovilli’s driver from ST’s to see if I can get past ~31 devices before the driver starts crashing, and I saw in the logcat for the driver these warning messages:
2024-01-12T13:46:44.608255010+00:00 INFO Inovelli Blue Series initialize
2024-01-12T13:46:44.618452635+00:00 INFO Inovelli Blue Series No color event received for ep1. Initializing value
2024-01-12T13:46:44.628916135+00:00 WARN Inovelli Blue Series Attempted to generate event for 44b21bb1-2c86-41cc-913f-0e402f29d4f3.main but it does not support capability Color Control
2024-01-12T13:46:44.639305052+00:00 WARN Inovelli Blue Series Attempted to generate event for 44b21bb1-2c86-41cc-913f-0e402f29d4f3.main but it does not support capability Color Control
2024-01-12T13:46:44.650111760+00:00 INFO Inovelli Blue Series No fan event received. Initializing value
2024-01-12T13:46:44.660651135+00:00 WARN Inovelli Blue Series Attempted to generate event for 44b21bb1-2c86-41cc-913f-0e402f29d4f3.main but it does not support capability Fan Speed
Anything I should be concerned about? Looks like the driver hasn’t been updated since October, and I can’t recall if these messages have always been there, so I thought I’d ask.
@Bry , I’m curious, how many Blue devices do you have in SmartThings?
Those messages won’t hurt anything. It is just because there are multiple devices that share that installation package. Doesn’t cause any problems though.
Having an issue with vzw31-sn with firmware 1.02.
When a routine sets the default local level, it is indeed changing the default local level but it is also changing the minimum brightness parameter. However, it is not reflected when you go into the settings.
Ie night routine sets the default local level to 10. The lights indeed do default to that level of brightness, however, the light switch will no longer dim further. , if you cycle the switch through on and off paddle taps. When the light turns back on, it is the same brightness. However, it is then represented as 1% brightness in smart things. And you can no longer dim the light dimmer. The settings still show an original minimum brightness setting of one, if you change the minimum setting it resets back, or if you change the default local level through another routine level, it then readjust but then still locks in that value as the new minimum brightness.
Interesting I will take a look at the driver to see what is going on.
Let me know if I need to provide you with anything.
@Lowman39 I found the error in the driver and just pushed an update to production. It should reach your hub within the next few hours.
@EricM_Inovelli
I just installed my NZW30 I bought a few years back. This one has the LED at the bottom instead of on the side. It needs to tap 6 times up to start pairing and unpairing. I can pair the switch with Samsung SmartThings hub. It is showing SmartThings driver for Z-wave switch devices but got error when trying to turn on/off.
I followed the instruction on Post#1 and added Inovelli Red drivers to my hub. Unpaired and then paired again. It shows the same driver. I had also try deleted the SmartThings driver from the account and start all over. No luck. The switch was paired with SmartThings driver again. I tried “Select different driver” in the device but “No results found”. Any suggestion?
The NZW30 is the original Gen 1 series. I don’t have any of those, but I’m guessing that you installed the incorrect driver. Uninstall the Inovelli Red Drivers and install the Inovelli 1st Gen driver.
More than likely, the reason the driver isn’t being recognized by SmartThings is because the fingerprint for the switch isn’t in that driver. That means the driver won’t support that switch, and in your case, probably means it’s the wrong driver.
Thanks for the prompt reply. I just uninstall other Inovelli drivers and keep Inovelli First Gen only. Unpaired and Pair again. SmartThings still not recognize the switch properly and used SmartThings Driver for Z-wave switch devices.
Post a screenshot of the driver menu from the switch please.
No, the one from the switch’s page. 3-dot menu, Driver
