State issues with Z2M and Home Assistant
I followed the information in this thread to create an automation that will set the adaptive lighting color temp and always have my lights primed. I am however seeing some odd behavior on my motion activated lights.
I am using dimmer switches with Philips Hue bulbs. I have created Z2M groups that include the switches and bulbs and have also bound each of the switches to the appropriate light group.
There are times when the light bulbs do not turn on or off as expected on my motion activated areas. If I tap the up or down paddle on the switch the bulbs will respond accordingly. I suspect that the switch is changing to the correct state. but the message isn’t getting to the bulbs for some reason. I always forget to check the individual statuses before getting frustrated and just clicking the switch.
Has anyone else seen this behavior? Is there something I should be looking at to resolve this?
Alright. It just happened again, so I did some more digging. Here is what I am seeing.
Bulbs: State is on, brightness is 0%
Switch: State is off
Group: State is on, brightness is 0%
