Switches go unresponsive after a few days without use
I have blue series dimmer switches installed and connected to home assistant using Zigbee. If a switch goes without use for a few days it becomes unresponsive. When this happens it takes three presses (doesn’t matter if pressed slow or fast) to wake it up, then it becomes usable again. After the 3 presses it works normally with a single press to turn off or on. Is there any way to prevent this so they always work when a button is pressed? It seems to affect every switch.
